disabling codes
Old 07-22-2015, 06:50 PM
blkchevyz's Avatar
Default disabling codes
so I disabled the rear o2 and I have the dtcs disabled through hptuners. I don't get a ses light but when I pull the codes I see this. need to pass safety and emissions, is this something they will see when they plug in?
[] P0036 - HO2S Heater Control Circuit Bank 1 Sensor 2 (Pending) (Old) (History) (Current) (Immature)
[] P0054 - HO2S Heater Resistance Bank 1 Sensor 2 (Old) (History) (Current) (Immature)
[] P0138 - HO2S Circuit High Voltage Bank 1 Sensor 2 (Old) (Immature)
[] P0141 - HO2S Heater Performance Bank 1 Sensor 2 (Old) (History) (Current) (Immature)
Old 07-22-2015, 08:17 PM
spawne32's Avatar
you need to change them to 3 - NO ERROR REPORTED in hptuners
Old 07-22-2015, 08:39 PM
blkchevyz's Avatar
thanks, I didn't even notice I could change that, I just figured uncheck it... im use to tunercats lol
Old 07-22-2015, 08:54 PM
blkchevyz's Avatar
do I need to worry about this stuff?
Once Per Trip Tests
Catalyst: Incomplete
Heated Catalyst: n/a
Evaporative System: Incomplete
Secondary Air System: n/a
A/C System Refrigerant: n/a
Oxygen Sensor: Incomplete
Oxygen Sensor Heater: Incomplete
EGR System: n/a
Old 07-22-2015, 09:21 PM
Sint3k's Avatar
Yes, it must be complete, or they will tell you to come back.there is a limit to how many monitors can be incomplete older cars is like 2, newer is 1I believe, but I'm sure all locations are different, just call your local emissions and ask how many monitors can be incomplete.Also, down in north Texas, you get like 3 chances to pass on the original fee.
Old 07-22-2015, 09:33 PM
spawne32's Avatar
Once Per Trip Tests
EGR System: n/a
catalyst is the easy one, just disable P0420 and that will pass catalyst. o2 heater requires the heater codes be disabled for both sensors, and the regular o2 test requires codes be disabled for everything related to o2 sensors. Evap i havent found a way to disable that test, but you can pass with it incomplete.
Old 07-22-2015, 09:34 PM
superglide9375's Avatar
u also have to drive some to get data built up
Old 07-23-2015, 08:11 AM
blkchevyz's Avatar
i thought i had the heater codes disabled already, could that be a case where i just need to drive it a little before it clears?
Old 07-23-2015, 09:58 AM
the drive is not to clear,if there is noe enough data stored in computer they tell u to bring it back have been dealing with this stuf for years in md,used to get false o2 sensors and that would send false signal but now with tunes that is obsolete
Old 07-28-2015, 11:02 AM
blkchevyz's Avatar
well added an o2 bung post cat. cleared the heater code but was still getting the catalyst one and evap. went ahead and reprogrammed it to remove the catalyst...
Old 07-29-2015, 08:57 AM
blkchevyz's Avatar
well **** it failed lol i didnt give it enough time to do the test for the o2 sensor after i reprogramed it. funny it cleared about 10 minutes after i took the car home.
Old 07-29-2015, 11:09 AM
IT will pass now just take it back
Old 08-05-2015, 02:21 PM
did it pass?lol
Old 08-06-2015, 02:52 PM
blkchevyz's Avatar
yeah passed without any issues 2nd time lol
Old 08-07-2015, 11:09 AM
nice to hear my man
Quick Reply: disabling codes
