Needed ls4 engine
A rotating assembly would be better I would think. The rods from your motor are most likely bent and it could have damaged the crank as well. Take your time here,don't try to rush this together. There should be plenty of motors available out there. The weekend is here, hit the junkyards and start making calls to all local yards. Negotiate a good price, don't pay what they ask either because it will need to be gone thru as well.
Plenty of these motors out there when I blew mine there was 3 at one yard got one with 28000 but I had to give him my old one 1200 dollars but I know the guy that owns yard
I have plenty of time I'm in no rush what so ever I'm going to do this right engine is gonna get fully built from valves down no matter the cost. The entire engine bay will get painted all fresh heat wrap nice catch can and v band on all of my exhaust system
Moderator
Is the motor beyond repair? has it been torn down yet? i mean if iw ere you id have it bored, and a thourough machine job done. The 5.3 under forced induction on stock internals can take alot of abuse. But it would be worth it to upgrade pistons. supercatxr7 will have a better parts list for you if you hit him up. He was the first fully built turbo motor i recall around here
