What could this be?
What could this be?
I'm getting abs and Trac lights on and off when I hit any type of bump sometimes they will stay on for a sec and also at times I get brake light. Wheel sensors are all new. I get a code u100 lost communication with abs module. Any ideas would be awesome
if your confident of the condition of the harness, id suspect the ABS module itself on the front of the ABS pump. Broken contacts inside the module at the power connection are a pretty common failure.
This sounds like what happened to my 2004 GP. I ended up replacing both the driver's and passenger's side ABS wiring harnesses. Here's the part I used, if the link doesn't work it's a Dorman part # 970-042, I bought them from Amazon.
Do the door locks or anything cycle when this happens ? Or the dash flash off and on ?
Yes that exact code and the other night it hit some hard rain and all the gauges droped several times I got home and parked asap
