So I finally started my LS6 intake swap and other mods...
Thought I would post a bit of what I started today. LS6 injectors (manually cleaned them and re-sealed them) and cleaned and sanded the LS6 fuel rail. Prime tomorrow, paint after. Other mods to follow, all parts are now accounted for. Headers, 1.8 roller tip rockers, beehive valve springs, valve seals of course, intake swap with LS6 rails and injectors and I already have a Diablo Trinity and 2 1/2 inch dual exhaust, x-pipe and flow masters and of course air intake. Check out the pics of the injector cleaning, pretty neat.
LS6 injectors, 12volt power supply, connectors, and speaker wire. Manually clean injectors? Seems legit.
Wired up the old harness connector to the power supply.
Carb cleaner, power, and we have spray! Awesome.
Finished for tonight. Cleaned the rail up and installed top and bottom and orings. More to come tomorrow!
You're going to want to reuse your stock injectors with some top hats on or another shorty style injector. Those LS6 injectors are from the e40 PCM and have missing tables that the e67 PCM in 07+ LS4s have. I'm running top hats from FIC with some 50lb injectors from newer 6.0s.
Originally Posted by SHOfastGXP
I had heard conflicting things about the injectors working and not working. Does anyone have the height adapters?
yep good choice i got cbm i think they look the same,not on now its for speedster man and ls3 tb that me and a friend are in a fistfight with to get to matchup-right spawne?lol
Moderator
Heres the data. For the ls6 inectors. Has all the data interpolated for use in newer ecms.
They work just fine.
https://drive.google.com/folderview?...nB5QjdqQXd5SUU
Moderator
Also the ls1/6injector is not a e40 pcm injector either. The good thing is it will fire up and drive to your tuner without a tune. Since we have pretty much identical flow rates with the exception being some short pulse adder and ign offsett changes. Otherwise you will be fine.
Some of the mods, Harland Sharp 1.8 roller tip rockers, NGK plugs, New wires, HAWK performance brake pads
New rotors
New tires for the front and rear
Valve springs
Transmission oil cooler
