Shift Kit & Trans Drain Questions
It looks pretty straightforward to install.
Which ones are you all using for the 4T65-HD (2008 Pontiac GP GXP)?
A shift kit is mechanical and increasing shift firmness on a Diablo is via PCM, right? Do these play well with each other?
While I'm there, I'm going to change out the pan to have a drain plug. Will this pan work? The Amazon part checker says it will not fit the "HD" model.
https://www.amazon.com/Dorman-265-81...=DORMAN+265814
I'm going to use this is as the filter:
https://www.amazon.com/ACDelco-TF304...XRZCN6E09ABD31
and reuse all gaskets.
When changing the transmission filter and draining it, how much fluid does one need typically?
Long story, but I will sum it up since you asked.
Thought process:
My 2nd fan does not come on (fixing that early next week), causing the car to run hot if I stop. This heat transferred into the transmission, causing the hard shift. I have read many examples on other forums where installing a standalone trans cooler + mild shift kit extinguished the problem if caught early enough.
I need a trans cooler anyways + trying a $50 shift kit is worth it.
If that does not work, I will call Dave.
Got any thoughts on my original post?
- Trans shifted hard in 1-2 Monday morning after sitting in stop and go traffic, so I parked it at work.
- Decided to give TEP a call the same day and was sold on it.
- Drove car since, the car runs great.
Thought process:
I have done 4 Transgo kits in my GP's, they work ok but I would look into an Intense kit next time. I would also not buy a new pan, just a trans drain plug from Rockauto for 3 bucks and extra magnets are critical(search magnets). 7 qts fluid plus Lucas is close. What is your mileage?
i have done 4 transgo kits in my gp's, they work ok but i would look into an intense kit next time. I would also not buy a new pan, just a trans drain plug from rockauto for 3 bucks and extra magnets are critical(search magnets). 7 qts fluid plus lucas is close. What is your mileage?
Why Intense kit over Transgo?
Thought process:
Thought process:
The transmission does have a table for shift firmness based on heat, but I would not be worried about it. These transmissions normally operate at 220 easy despite what you might read. Id worry about your 2nd fan first before investing in a transmission, "if" the harsh shift is your only concern.
What does the Intense kit have that the Transgo doesn't for $42? Just some pads? I have never heard anything wrong with Transgo, relative to the millions of kits that are sold by them.
Is this the proper Transgo shift kit? It doesn't say for the HD version, but I'm assuming it will work based on the comments.
https://www.amazon.com/Transgo-T8416...nsgo+Shift+Kit
Random "newbie transmission" question coming. Are shift kits not harder on the transmission, thus doing the opposite of what I want?
I did notice a "delayed" shift yesterday when it was cold, from 1-2, but it was gone after 10 minutes (warmed up). The standalone cooler may make that worse. However, I read that the Transgo kit has a "fix" for that in the kit, but you have to dive deeper into the transmission. Does that ring a bell to anybody?
Thanks everyone.
If you examined the contents of the Intense kit and compare it to the TransGo you really would not need to ask the difference. Yes that is the right TransGo, here it it 6 bucks cheaper.
http://www.ebay.com/itm/Transgo-Shif...dU45dR&vxp=mtr
Just like the last convo (remember the jack set?) - I'm trying to find the right part or part number. It doesn't mean I'm going to buy it there.
Back to my tech questions:
Will do - I'm getting the fan issue fixed next week (trusted friend/mechanic).
Thanks everyone.
Thanks everyone.
My car has the transgo kit, but mine was rebuilt by TEP. You cannot really judge any shifting while the car is cold. There are temp tables that allow for more slip when the transmission is cold. There is a forward seal that eventually leaks, but this will cause a, "Gear drop out while at idle and in gear", so you get a shift bang. Odd things will happen, I would not take it as a sign of anything unless it was duplicated daily etc.
Where is this forward seal? External or is it within the transmission?
Installed the shift kit this morning - feels good so far. It is a very easy install, just messy.
I'm 99% sure the transmission fluid has not been changed. The bolts looked untouched (105k) and it was dirty. It took just shy of 8 quarts to fill it back up.
My factory magnet (circle type on the 2008) had quite a bit of sediment on it, completely covering it.
The only regret I have is not buying a new clean Dorman pan with a drain plug.
I also wish I would have taken a picture before bolting everything back up. There was place in the transmission where you could see up into it. It looked like a "band" of some sort with a gap, but I was not sure if it was broken or not. Does anyone know what I'm talking about? I know I did not explain that real well.
Here it is between the two hard lines:
http://s727.photobucket.com/user/1fa...ro032.jpg.html
