Help with Power Steering problem!
I just recently changed my power steering pump with a AC Delco remanufactured pump and while I was at it I replaced the hard line portion of the return line with some earls stainless braided hose since the old one was getting pretty rusty.
The problem I have is as the car warms up to temp I have no power steering at a dead stop or if I am barely creeping along only, but the longer I drive it the worse the problem gets as I will start to lose power steering even when I am moving. If I let it sit over night and cool down, the power steering will work again right when I start it up even at a complete stop...until it warms up.
I have bled the PS system three times now. Front wheels off the ground, turning the wheels side to side. All I can think of is that section I replaced with stainless hose must be the problem. Maybe the hose is collapsing?
Its a hard line that leads to the reservoir and then goes just behind the alternator and then to a factory rubber hose that I replaced.
I'll get a picture tomorrow in the daylight.
That makes me think the pump is garbage then since the line would more likely enlarge. I thought as the pump pulls fluid through, it might cause the hose to collapse...
Thanks for the help.
I tried replacing the pump with a new Delco pump rather than the remanufactured one and the problem is now gone!
So if any of you ever need to replace your PS pump in the future, don't waste your time on the remanufactured Delco one. Thanks for the help guys.
