LS4 Heat Soak Reduction Kit
LS1Tech Sponsor
how'd and where'd you mount the sensor??
have any pics??
have any pics??
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Did not know this company existed. Looks like a good part. Anybody purchase the ecm? I see alot of people using the HP or diablosport tuner but I am pretty out of touch with the tuning thing so a pre programmed unit may work for me.
How ever I am very intrested to see if people notice a difference with this heat soak. Because when I scan my IAT at idle it runs around 140 and driving around 90 which is freaking hot you knock off 10 degrees and that would add alot of timing lost to the heat.
LS1Tech Sponsor
right, but at the end of that harness is the actual IAT sensor... some people have put them inside their filter/CAI box, some mounted it to the front support, etc etc...
curious as to how live2ride mounted the sensor...
__________________
I have the hsrk off of my 06 Impala, I didn't test the two next to each other but I do know that the vector sensor reacts instantly. I hooked up a tech 2 to the car and installed the senor with out mounting it and blew air from an air hose on it and it immediately reacted. I also bought one for my Trailblazer SS form vector since the connectors are diff. I'll sell the one for my 06 Impala SS if anyone is interested, $50. With the stock intake I zip tied it to the inner fender at the edge of the stock inlet. It's ok to get the sensor wet.
Originally Posted by SILVER LS4
I have the hsrk off of my 06 Impala, I didn't test the two next to each other but I do know that the vector sensor reacts instantly. I hooked up a tech 2 to the car and installed the senor with out mounting it and blew air from an air hose on it and it immediately reacted... With the stock intake I zip tied it to the inner fender at the edge of the stock inlet. It's ok to get the sensor wet.
LS1Tech Sponsor
Originally Posted by Corny40
I'm confused.
__________________
I have heard too many stories of people that have had bad experiences with this company. I tried once before all that and couldn't get them to return my calls. I will never use nor trust them ever.
Originally Posted by 06MonteSS
about what man??
"The kit includes all plug and play OEM quality components with no need to splice or cut the factory harness"
so why all this talk about drilling and such?
LS1Tech Sponsor
cuz, at the end of that harness is the actual IAT sensor - you have to put that somewhere, so a lot of people drill a hole in the end of the K&N cone filter (in that chrome cap on the end), put a grommet in the hole, and then stick the IAT sensor in it.
__________________
LS1Tech Sponsor
the stock location on our cars is inside that hard plastic MAF housing... that's the other wire inside there... so it'd be impossible to do that... and defeats the purpose anyway, since that plastic housing causes heat-soak that you're trying to eliminate in the first place.
if you're thinking of that black tube/plug at the top of the intake tube in front of the throttle body, that's the crankcase vent tube...
__________________
LS1Tech Sponsor
if it works like they say it does, yeah... I've read posts on other forums from people that have it and they said it works good... said it was definitely worth the money...
now my problem is, finding the money between this and the flowmasters I wanna get...
__________________
