Monte Carlo Power Door Locks - LS1TECH
Thread Tools Search this Thread
Old 03-26-2008, 08:14 AM   #1
Count of Monte Carlo's Avatar
Default Monte Carlo Power Door Locks
If you put the key in the lock cylinder and turn the key one way should the doors lock, turn the other way and unlock? Also my key is alittle hard to push in just at the end of travel.
Count of Monte Carlo is offline   Reply With Quote
Old 03-26-2008, 10:40 AM   #2
Taz34SS's Avatar
No, on mine the doors will not lock untill you put in it in gear.
Taz34SS is offline   Reply With Quote
Old 03-26-2008, 12:00 PM   #3
Acutally I ment if you use the lock cylinder on the door.
Old 03-26-2008, 12:23 PM   #4
On my Imp I can unlock the drivers door using the key in that door, that's it. Not sure what happens if you try and lock I've never done that.
20SS07 is offline   Reply With Quote
Old 03-26-2008, 01:12 PM   #5
BuffaloSS's Avatar
I believe the Imp will unlock the DS with one turn, then turn it again to get them all to unlock. Will check when I go to lunch.
BuffaloSS is offline   Reply With Quote
Old 03-26-2008, 01:39 PM   #6
Hmm never tried a second turn. I'll have to try too.
Old 03-26-2008, 01:40 PM   #7
LS1Tech Platinum Sponsor
06MonteSS's Avatar
hmmm... have never used the lock in the door..
always use the remote...
06MonteSS is offline   Reply With Quote
Old 03-26-2008, 01:52 PM   #8
bigboy3l's Avatar
Sad to say never used the door key holes LOL.
So Lazy
I'll have to check after work.
bigboy3l is offline   Reply With Quote
Old 03-26-2008, 04:05 PM   #9
Heaven knows why I even bothered to stick the key in the door....But I did hehehe. Anyone who can find out what it is supposed to do other than lock and unlock the driver door I would really appreciate it.
Old 03-26-2008, 04:32 PM   #10
I don't know about the Monte or Impala Count, but I have had vehicles in the past that if you turn the key to the unlock position and hold it there, it would unlock all the doors. It did not work to lock them though.
CTBSS is offline   Reply With Quote
Old 03-26-2008, 06:12 PM   #11
It does lock and unlock the way Buff said. One turn unlocked the drivers door, then turned again for all of them. Not that I'll ever have to do that again since I just use the remote.
Old 03-26-2008, 07:22 PM   #12
BuffaloSS's Avatar
I bought my '96 explorer in 2001 and not one lock cylinder worked. I replaced them all after my battery died and I had to nearly break the liftgate glass to get in. In the Imp we only have one, so I make sure to use it once every couple weeks to keep it operational.
Old 03-27-2008, 02:57 PM   #13
BuffaloSS's Avatar
And on ^^^^^ note, just used the key on my way out to lunch a little while ago. It was almost frozen shut with salt buildup. I guess I haven't been practicing what I preached. Was able to tap the key a few times to break the "seal" and then it took a little force to get the cylinder to turn. Going to get some lock lube this weekend. With this shitty keyless entry system, it's only a matter of time until it fails completely.
Old 03-28-2008, 04:25 PM   #14
Hehehe dont break the key off in there LOL. Well I tried my key again and when I lock it it locks the driver side only. But unlock..if i turn th ekey twice in th eunlock position it will unlock the passenger side as well.
Tags
06, 2006, automatic, automatically, carlo, carlos, chevy, door, lock, locks, monte, position, unlocks, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
