N20 on Stock LT1
N20 on Stock LT1
I tried a search couldnt find anything!
my car in sig........i want to possibly hook up N20.
The internals are stock!
what kit should i go with and what is a good amount to shoot on a stock motor? what is WET and DRY Kit?
Are they hard to hook up?
When I purchased my kit I knew nothing about nitrous! This read really helped me out: https://ls1tech.com/forums/nitrous-oxide/846230-everything-nitrous-related-stock-bottom-end-all.html
When I purchased my kit I knew nothing about nitrous! This read really helped me out: https://ls1tech.com/forums/showthread.php?t=846230
dont run a dry kit on a LT1, not a good idea. The computer cant keep up with the juice, so all the kits out there raise the fuel pressure to provide the extra fuel. The stock injectors were never meant to do anything like this. This is the main reason why i wouldnt go dry with a LT motor. LS, they are fine, LT no way.
The limit for LT1's is a 150 shot, people go higher but there are many risks involved. I would say a 150 shot is okay provided your going to buy all the safety items needed.
The install isnt too bad if you know what your doing. But if not you may want to get a buddy whose handy or take it to a shop. I personally dont do my own kit, a buddy does my work because it am not confident in myself. I would advise something similar if you dont want to give it a go.
I would go with a kit from Nitrous Outlet. They will work with you to make sure you get what you want. I have spoke with Ray and Dave there, both are stand up guys.
I went with HSW and the guys helped me constantly! My entire kit is from HSW and they helped with every question I had before and after purchase, Like I said I knew nothing about nitrous when I purchased the kit, I had bought it because HS had a huge christmas sale. LOL With that being said I got my window switch from Nitrous Outlet and they helped too.
This is the best kit for our cars no doubt!
http://www.nitrousoutlet.com/catalog...roduct_id=2809
Im interested in this, is the link you posted for everything u would need to safely install the kit onto an lt1 car??? Im lookin at buildin my motor with le2 head and cam with full bolt ons and suspension mods and stuff in a few months here hopefully. If i can safely add juice without worrying about blowin my motor sky high i might actually look into it.
okay so im thinking 75 shot i dont want to get to greedy ya know and blow the motor i just want that little extra!
So from what i read the DRY kit is easy to install, but everyone says go WET?
Can i go DRY? I am pretty mechanically inclined i do all the work on my car and had no problems with anything i have fixed!
Is this a good kit?
i ahve always purchased everything for my car off ebay and never had a problem!
http://cgi.ebay.com/ebaymotors/Brand...mZ370090141210
Is this a good kit?
That kit will be fine, even though its a brand X, its still good, but awhole lot cheaper.
man people always say dry kits are dangerous..and they are not. i wouldnt run a 200 shot dry but have sucessfully ran a 125 shot for more than a year with not one problem..just make sure you run premium gas, get a step colder spark plugs gapped at 035-.040 and you will be set. and put your nozzle before the maf..
Guest
Posts: n/a
Is this a good kit?
That kit is a Nitro Dave's kit
and dry kits are no easier to install than a wet kit.
Go For A Wet Shot For 100hps Or 75 But "wet"
If You Dont Have Time To Buy Your Tr6 , Put Yours Tr55 At 0.040
And I Recomend A Ignition Box 6a Or 6al
And Let Me Know Your Time In Sacramamento Raceway
