umi torque arm question
Old 10-15-2008, 02:47 PM
shutzero's Avatar
Default umi torque arm question
whats the difference between the adjustable torque arm with tunnel brace and the one that doesnt have the tunnel brace
Old 10-15-2008, 04:09 PM
the_merv's Avatar
The one witout the Tunnel Brace mounts to the back of the Transmisson in the stock mounting place.
Old 10-15-2008, 08:42 PM
shutzero's Avatar
but dont they sell one without the tunnel brace thing going around the driveshaft but still mounts to the brace?
Old 10-15-2008, 08:44 PM
shutzero's Avatar
this one http://speed-eng.com/store/umi-torqu...es-p-8675.html
Old 10-15-2008, 09:22 PM
Elliott's94Z's Avatar
Originally Posted by shutzero
Yes, thats the one that removes it from your transmission. I have the opposite one on and like it a lot. I would rather have this one though
Old 10-15-2008, 09:23 PM
shutzero's Avatar
whats the difference between that one and the one with the tunnel brace
Old 10-15-2008, 09:35 PM
the_merv's Avatar
Not much in a way.. the one with the Tunnel Brace came out before they released something like that I beleive..
Old 10-15-2008, 09:38 PM
shutzero's Avatar
like does the tunnel brace offer anything performance wise that the other one doesnt?
Old 10-16-2008, 01:13 PM
YORK_MUSTAINE's Avatar
+1
Old 10-16-2008, 01:29 PM
+50 HP It just free's up the stock torque arm from the transmission.
Old 10-17-2008, 08:51 AM
UMI Performance's Avatar
Hello,
The tunnel mounted torque arms are shorter style torque arms that mount in the tunnel area of the vehicle approxiametly 12" behind the transmission. The shorter arms work very well on high horse-power vehicles to transfer weight and plant the rear end into the ground. Here is a picture of a tunnel mounted torque arm installed- http://www.umiperformance.com/images/2203e.jpg
A transmission mounted torque arm bolts into the exact location of the factory torque arm... they are longer then the tunnel mounted arms and work better in handling applications. Here is a picture of a transmission mounted torque arm installed- http://www.umiperformance.com/images/2205f.jpg
I can go into more detail if needed... just let me know. You can also give us a call at 814-857-5400 and speak with a tech rep.... they can offer some very valuable information over the phone.
Thank you!
Ryan
Old 10-17-2008, 08:58 AM
LS1 SPEED's Avatar
Originally Posted by UMI Performance
Hello,
Thank you!
Ryan
what he said
Old 10-17-2008, 01:46 PM
the_merv's Avatar
^^My Tunnel Brace one is doing alrite for handling..
Old 10-18-2008, 08:46 AM
multmigs's Avatar
Default I just put this TA on my car
Just finished bolting the longer trans mounted version of the UMI TA on my car, brief ride this Am sounds same as stock, seems to be a bit more initial bite less wheel spin when gassin it hard, and it was cold this AM which usually equals wheel spin, very easy to put on definately a heavy duty piece, I have to do some investigation about setting the angle since I bought the adjustable version but I am planning a trans swap so I also bought the trans cross member from them which moves the TA attachement point so I will do that afterward and see what happens then...
Quick Reply: umi torque arm question
