cam selection help
Old 10-20-2008, 10:48 AM
johny's Avatar
Default cam selection help
hey guys i just got my motor back from the machine shop. still a 350. i also have ported and polished heads stock lt1 heads. i have long tubes headers and a 58 tb. i just need some help with the cam selection. I'm looking for something that can get me to 350-370 RWHP NA on my 6 speed. thanks.
so far i heard of the 306 cam and some XFI comp cams. i would like a XFI cam that can get me there since I've heard there better for a daily.
Old 10-20-2008, 10:53 AM
Jditlfm's Avatar
advanced inductions or elliottsportworks google those names either one is the only option i would consider. not sure if its true or not but i heard those xfi cams like to eat valve springs. Also the post at the top of the page https://ls1tech.com/forums/lt1-lt4-modifications/836200-stock-head-cam-cam-swap-guide.html
Old 10-20-2008, 10:57 AM
slomarao's Avatar
go with a AI or LE custom. Both have put down lots of power in many different applications.
Old 10-20-2008, 11:29 AM
johny's Avatar
I'm using beehive springs.
Old 10-20-2008, 12:55 PM
johny's Avatar
looking for something off the shelf.
Old 10-20-2008, 01:09 PM
Elliott's94Z's Avatar
I would disagree with this...look into a Lloyd Elliott custom billet cam. You will get better gains with one of his custom cams then a off the shelf cam no doubt.
Old 10-20-2008, 01:12 PM
lt1z28camaro's Avatar
Which is basically an off the shelf cam now isn't it? Considering you can see the specs and gives you a little background on each of them. I also agree with looking into www.elliottsportworks.com or www.advancedinduction.com
Old 10-20-2008, 01:16 PM
No, it is not a off the shelf cam. Lloyd custom grinds it...plus its a billet cam which the shelf ones are not.
Old 10-20-2008, 01:21 PM
Oh my bad, I just assumed off the shelf meant basically anyone can have them and custom grind is specific and rarely anyone has the same cam, thanks for informing me.
Old 10-20-2008, 01:26 PM
strokin93z's Avatar
just search around. CC306 or GM847 should get u there. Good luck with cam selection.
Old 10-20-2008, 01:30 PM
The list of cams on Lloyds web site are his own custom grinds of some popular cams such as the Hot Cam, Crane 227, CC306, CC503 etc etc. He can custom grind you a cam to the specs you want for your application.
Old 10-21-2008, 12:59 PM
LS1TECH Sponsor
NightTrain66's Avatar
cams listed on my site are given to customers about 50% of the times and designed to work with LE1 heads and the springs I use on them. They were designed for the most common set ups that people have. Sometiomes they are still the best choice with LE2 heads but sometimes not.
People using LE2 heads and the Patriot Gols Extreme springs will be able to use more lift and more aggresive lobes.
Most customers calling for a cam only set up and using bee hives or Patriot Gold Extremes will open up the options on how aggressive the lobes can be.
Even people buying my heads or a cam only set up and Crane dbl springs can end up with different a cam than listed on my sitre just based on there set up and what they are wanting it to do.
Lloyd
Old 10-21-2008, 05:07 PM
slagger's Avatar
well I just finished my build and I have the 227 cam and wow I can tell you that this cam pulls great maybe its my set up but what a differance this is compare to my AI custom grind not to talk bad but I couldn't hit second gear chirps with it but the 227 differant story I have never drove a car that pulls this hard in second gear.
Old 10-21-2008, 05:25 PM
Yeah, from what I have seen and heard that cam is a good one! Glad to hear you like it. How about a video of a huge burnout!
Old 10-21-2008, 07:48 PM
slagger's Avatar
deffently, i'm still in the process of tuning but once i'm done tuning i'm going to get it dyno to see what kinda of power it is putting out.
Old 10-21-2008, 07:56 PM
ClovisAutoMotion's Avatar
+1 for the 227, I had one before in my camaro and loved it. Great street manners, solid power curve, and you don't need to spin the **** out of the motor. Unfortunately I sold it because I wanted to go bigger. I just bought another one to stuff in my daily driver. Oh and the cranes are on a billet core as well.
Old 10-21-2008, 08:44 PM
slagger's Avatar
yeah right now I have it shifting at 6200 rpm but i'm going to lower it to 5900-6000 and see how that goes were still in the process of tuning and playing with the shift tables,ect,
but even when I took it to almost 6200 it felt good.
and like you said great street maners but at a light or parked when its ideling it sounds good with my magna flow a good low rumble sound.
all I have to do is get some better bitting tires, right now I have evo 245/50/16 but they are 3 yr old.
and been loosing the bit they had before.
Quick Reply: cam selection help
