2.02/1.60 worth it with my setup?
Old 10-20-2008, 11:15 PM
Green3spd's Avatar
Default 2.02/1.60 worth it with my setup?
I plan on going with a stock bottom end(rod bolts, main girdle, main studs), with CC306, ported Stock heads and Ported stock Intake manifold...
Would it be worth it to install 2.02/1.60 valves? I know it would benefit from it but would it actually be worth the money to have my heads machined and the whole 9 yards...?
And to go ahead and get this out of the way... Im not buying aftermarket heads... budget build..
Old 10-20-2008, 11:20 PM
1badzee's Avatar
It's definately worth it
Old 10-20-2008, 11:23 PM
fergymoto's Avatar
May not be worth it. You will have to go to bigger intake seats I know for a fact, I *think* the exhaust seats will take a 1.600 valve but can't remember for sure. Some of the best LT1 heads out there use 2.00 and 1.560 valves and these work on stock seats.
Old 10-20-2008, 11:26 PM
1badzee's Avatar
So it's not worth the $150 to machine the head and seat larger valves?
Old 10-20-2008, 11:30 PM
fergymoto's Avatar
If it were you would be seeing it done more don't you think??
Old 10-20-2008, 11:35 PM
1badzee's Avatar
I see it done all the time down here in sofla lol
Old 10-20-2008, 11:45 PM
Ls1Bait's Avatar
Its done quite often on stock heads. I was thinking about it on my heads but I spent the money on porting instead, so when I build a forged 355 I will have it done
Old 10-20-2008, 11:47 PM
Slowmaro95Z28's Avatar
I'm doing a similar setup and my engine builder said basically that it is not worth the money for the tiny gains if any you will see. After the long explanation I see what he means. If you have the money to blow see what happens but for a budget build forget it.
Old 10-20-2008, 11:57 PM
Ls1Bait's Avatar
Yea I would have to agree if ya got the money why not but a set of AFR's would be much better spent on!!!!
Old 10-21-2008, 02:07 AM
robsquikz28's Avatar
do it it will help 4 sure
Old 10-21-2008, 09:10 AM
LS1TECH Sponsor
NightTrain66's Avatar
The stock valve setas are only 2.00/1.56 so if you machine the seats as large as possible, a 2.00/1.56 valve fits perfect.
If you use a 2.02/1.60 valve, you are just placing a larger valve in front of the seat and same size hole so the air has to go around more valve diameter before entering/exiting the cylinder. You will lose flow and HP over a 2.00/1.56 valve.
Lloyd
Old 10-21-2008, 09:39 AM
BigZee71's Avatar
Why not spend the money on a 3 or 5 angle valve job or SS swirl polished valves? Or better yet some valve terrain upgrades.
Old 10-21-2008, 09:49 AM
Green3spd's Avatar
...Ya.. I planned on that too, lol..
so you I should think about doing 2.00/1.56 valves instead?
Ive never bothered a set of heads.. what would it take to install 2.00/1.56?
Old 10-21-2008, 09:54 AM
3DFORMULA's Avatar
Yes
Old 10-21-2008, 10:13 AM
koolaid_kid's Avatar
I suggest speaking to Bryan at portandpolishing.com before doing this.
Good work good prices, etc. A second/third opinion never hurt, and he did right by me.
JMHO.
Old 10-21-2008, 11:42 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
The best thing you could do is get a set of stock LS1 valves (2.00 / 1.55) and have the guides switched out. Having the guides switched should cost about $150. You can get a set of LS1 valves for about $30-50. Then, add the $150 = $180-200. That's less than you'd spend on a set of 11/32 aftermarket valves. You'll have a larger valve than stock, thinner stem diameter that'll flow more air, and do it on a budget.
You also either have valve springs or will need a set. You can order a set of Patriot Golds (LS1 ones) for $250 and be set.
Quick Reply: 2.02/1.60 worth it with my setup?
