kwik ?
Old 10-23-2008, 03:50 PM
snk-huntr's Avatar
Default kwik ?
Does anyone know why I would be getting water in my oil after installing guideplates and new roller rockers?
Thanks in advance
Old 10-23-2008, 03:53 PM
Chevyguy358's Avatar
yea..you need to put sealant on all of the headbolts and rocker studs before torquing them down
Old 10-23-2008, 06:24 PM
Formula350's Avatar
That made no sense in regards to his problem. Unless he removed the heads to install guide plates and rockers
I can't tell you what's wrong though, Snk. Sorry :\
Old 10-23-2008, 08:22 PM
fergymoto's Avatar
It really can't have anything to do with the mods you just did. Is there actually water in the oil or are you just seeing some whitish looking substance in the oil fill cap or "ceiling" of the valve covers?
Old 10-23-2008, 08:49 PM
What exactly doesn't make sense? rocker arm studs have to be removed to put guideplates in...I don't remember off hand if our reverse cooled heads have the coolant ports just below the studs or not, but I believe Gen I motors do
Old 10-23-2008, 09:42 PM
and yes fergy is correct...coolant usually shows up as a foamy white build up on the inside of the valve covers
Old 10-23-2008, 09:45 PM
fergymoto's Avatar
What I was getting at was I was trying to figure out if he was just seeing some moisture in the crankcase when he had it apart or if there was actually water in the oil when he pulled the dipstick.
Old 10-23-2008, 09:47 PM
James Montigny's Avatar
Thread sealer on the rocker studs. Very important.
Old 10-23-2008, 09:54 PM
fergymoto's Avatar
Only on the intake studs
Old 10-23-2008, 10:01 PM
snk-huntr's Avatar
i pulled the drivers side plugs out a few minutes ago and cranked the engine and water shot out of the rear plug hole, oil is creamy, i have some steam coming coming from the exaust, no over heating issues but the passed couple of mornings the motor seemed to be hydrolocked and took a few tries to get it to crank over. just hope i didn't damage the rings becuase i noticed alot of blow by also.
Old 10-23-2008, 10:04 PM
fergymoto's Avatar
There's really only a few things it can be.
-Head gasket no longer sealing
-Head cracked
-Crack in the cylinder bore
Don't crank it over any more with plugs in it, you can bend the rod.
Old 10-23-2008, 10:08 PM
Exactly ... liquids don't compress, they break stuff.
Old 10-23-2008, 10:17 PM
xx_ED_xx's Avatar
and that is why i got my car so cheap. They turned it into water injection
Old 10-23-2008, 10:32 PM
Blown head gaskets are pretty easy to replace if you are comfortable with bolting things together.
I picked up my beater that way dirt cheap, fixed the head gasket and ended up
with something I could drive while the Hawk's motor was bring upgraded.
If the block is cracked, that's a whole different story.
More work involved, but a good opportunity to pick up a decent motor
from someone who ran out of funding or initiative on their own project.
Old 10-23-2008, 11:55 PM
Formula350's Avatar
Now, I will not say I know this for certain, but aren't our heads not very coolant filled? So the bottom of the studs really only has the steam hitting them (hence the steam pipes) and I'd think that wouldn't be near enough to show quantities of coolant in the oil. (In this situation, toss aside the fact he has water in the cylinders so it's a different problem)
Old 10-24-2008, 12:32 AM
no, the coolant does pass through them...if it didn't then the aluminum would warp in no time, its simply a question of where those coolant passages are located. and yes if he has coolant in the cylinder then that is a completely separate issue
Old 10-24-2008, 12:39 AM
All of the intake threads go through the head to the lifter valley which has oil in it....i had to re tap them on my last motor...there seems to be alot of miss guided information posted on this thread. no offense to those who have posted
Old 10-24-2008, 05:50 AM
fergymoto's Avatar
I was talking about the rocker arm studs that are in the roof of the intake ports. No bad into there:shrug:
What you are referring to would be the intake manifold bolts...
Old 10-24-2008, 11:00 AM
Formula350's Avatar
Well, no, I know it has coolant flowing through lol I just meant that it wasn't filled to the brim with it :\
Old 10-24-2008, 03:36 PM
sorry 350 and fergy...my misunderstanding
