96 motor in a 94 car, cps sensor on 96 causing 94 not to spark with 96 opti??
Old 10-24-2008, 12:08 PM
Cross's Avatar
Default 96 motor in a 94 car, cps sensor on 96 causing 94 not to spark with 96 opti??
Ok I was not sure how to title this but those that know me know I swapped my motor out of my 96 z28 into a 94 formula.
I have had no spark, replaced the opti everything no spark. The opti has no high or low.
So I gave it to a shop when we could not figure it out.
They came back with this:
The 96 motor has a crank position sensor, the 94 does not.
But for this 96 motor to RUN you must have the cps signal for the opti.
I have the old harness but would rather just splice in the wires for it.
So some questions:
1) is this true, putting a 96 obdII motor in a 94 obdI car it will not spark due to the newer opti and lack of a cps signal?
2) people have converted over to vented optis so how did you get around this? (I am at work on my sidekick so searching is not an opti right now or I would)
3) if this is the problem where should I splice in and how for the connector and wires for the cps on a 94 ecu/wired car with the 96 cps connector?
Thanks guys hell if you want to text me things that would rock too.
520 302 eight five zero two
Old 10-24-2008, 12:14 PM
xx_ED_xx's Avatar
Um a friend of mine recently did this he changed everything in the car all wiring harnesses etc. from back to front and used everything from the obdII car
Old 10-24-2008, 01:11 PM
halucinator's Avatar
So some questions:
Since 94s didn't utilize a cps. You should haven't have a problem with anything. Did you happen to try a new icm?
Old 10-24-2008, 01:27 PM
Cross's Avatar
Yes tried a new icm I am back to the opti again. I called speartech (great guys there) and they confirmed its not possible for it to be the cps.
Oh the joys...
Old 10-24-2008, 01:34 PM
jarretthise's Avatar
man keep talkin to jon over at speartech he will work you through everything and get it running if it has anything to do with the wiring....man dont give up bro
Old 10-24-2008, 01:44 PM
Cross's Avatar
He is busy but I am trying, great guy but not something easy for over the phone
Old 10-24-2008, 01:47 PM
he knos these harnesses like the back of his hand man...just explain and elimate every single thing you have done and make sure your clear with him and he will figure it out.....you have an aftermarket ignition box in this thing
Old 10-24-2008, 02:16 PM
Cross's Avatar
Nope stock ignition and he already told me he can't really do it over the phone
Old 10-24-2008, 02:18 PM
Smokinlt1's Avatar
I got a 96 in my 94 and Im not using CKP sensor. Fired right on up on 1st try. There's nothing plugged in where wire is supposed to be. Hmm.
Old 10-24-2008, 04:48 PM
ok well goodluck! if he cant then i doubt your going to find a whole lot of help here
Old 10-24-2008, 04:52 PM
Cross's Avatar
Its hard even for him (Esp with a business to run) to expect a solution without seeing the car and only going off what I tell him.
1) He would be doing it for free
2) He has work to do that pays
3) He can not see it himself
So I am asking quite a bit of him and honestly... I feel bad asking too much. He has a business to run. I will call him when i feel I have solid info but he seemed to make it clear he was busy and could not do it without the car.
Old 10-24-2008, 06:58 PM
Smokinlt1's Avatar
You r using 94 computer right?
Old 10-24-2008, 07:29 PM
Cross's Avatar
Yes and we did the test with a brand new GM Opti and just plugging in the harness and coil wire then turning the shaft and it was sparking.
So I am returning the AZ Opti, charging them and getting the parts together to pull the Opti and put on an MSD one tonight. I should have the MSD one shortly.
Old 10-25-2008, 03:07 AM
Cross's Avatar
MSD is in.... still no spark. I hate my car.
94 Formula with a brand new LT4 for sale.
Old 10-25-2008, 09:10 AM
IllusionalTA's Avatar
get rid of the MSD's.. seen more ign. related problem's due to that.. than anything else... Check all your grounds...
Old 10-25-2008, 11:03 AM
the_merv's Avatar
Whatever it is, it's small. I'm leaning toward a break in the wiring..something small like that. All you did was change the Engine, CPS won't affect nothing if it's bot plugged in on a car that wouldn't read it anyways.
Old 10-25-2008, 11:10 AM
joshprescotttttt5's Avatar
did you even check out wat i posted in your thread on ltxtech?
it could be your problem, it was mine when i put in my 93 lt1 into a 96. had exact some problems as you are having.
Old 10-25-2008, 11:14 AM
Cross's Avatar
Since I never put the 96 harness in I was thinking about it. No I did not do that as its all still stock from the factor 94 wiring in the 94 formula.
Quick Reply: 96 motor in a 94 car, cps sensor on 96 causing 94 not to spark with 96 opti??
