4l60e problem
Old 10-25-2008, 10:31 AM
AAK z28's Avatar
Default 4l60e problem
my car was originally a v6 car then i put an lt1 in it with everything the motor is a 94 and i got a trans that is a 95 n then i drove it around but it didnt really wanna go anywhere it would just rev up really high then finally shift...any1 see a problem here? does it matter the year difference or that the car was originally a v6..mab bad converter?
Old 10-25-2008, 11:01 AM
the_merv's Avatar
Sounds like the Clutches are wore out, lime for a rebuild.
Old 10-25-2008, 04:40 PM
black95formula's Avatar
+1 sounds like clutchs. just dont use that case for the rebuild. try to find a case that has the letter K on it. stronger case that was used with the v8 in our cars as long as the vettes and trucks. well thats what i was told when i was searching for a new case to start fresh.
maybe someone knows and prove me wrong.
Old 10-25-2008, 05:34 PM
the_merv's Avatar
He's not using the V6 Transmission bro, the Bell Housings are no where the same if I'm not mistaken..I know they aren't on the newer stuff.
Old 10-26-2008, 06:24 PM
yea your right the bell housing are completely different,only the 4.3 has the same bell housing. i was also completely wrong about the internals being "weaker". sorry. (found a whole thread on the "myth")
did you changed the fluid before the swap? did you notice if it was discolored or burnt?
Old 10-26-2008, 06:36 PM
jarretthise's Avatar
there would be no reason for the cases to be different at all!! they are made out of the same ALUMINUM!!! bellhousing is different and the internals are built differently...they wont hold as much power as a v8 will...
on second thought though it sounds to me like your cluthes as well
Old 10-27-2008, 04:59 PM
AAK z28's Avatar
everything was fine a couple of ppl are sayin that the internals between the 94 and 95 are differenet. my motor and computer are 94 and the 94 computer is telling the 95 trans to shift like a 94 trans..any1 kno if that can be tuned out?
Old 10-27-2008, 06:53 PM
yea anything can be tuned
Old 10-27-2008, 07:52 PM
CamaroRacing12's Avatar
when i pulled my tranny and sent it to cahill performance transmission in DE the fluid looked like 3,000 mile motor oil btw i def recommend him... small operation, very helpful and considerate.... FLT is another place i would recommend i have only heard great things from them... when the time comes for a th400 or glide i will go to them... but u cant beat the personal relationship and 4l60e knowledge u can have with cahill performance transmissions, Frank Cahill is a great guy
Quick Reply: 4l60e problem
