5w-20 anyone?
5w-20 anyone?
The car i just bought came with 5 qts of 5w-20 mobil 1 fully synthetic in the back and im thinking of changing the oil with this stuff. Usually i run 10w-30, but im thinking about running this stuff just for about 500 easy miles or so during clutch break in, and then switching back to 10w or 5w-30 mobil 1. anyone see any problems with this? I just don't want those 5qts to go to waste if its not going to do any harm.
I was reading lots of people praising that german stuff, and I thought some were even running 0w-20... Which, wouldn't that basically be the same as the 5w-20 (aside from the cold start thickness). I still don't fully understand the oil ratings, so these are sincere questions.
the only german flavor of castrol syntec is 0w30....
essentially yes a 0w20 and a 5w20 are in the same accepted viscosity range for 20 weight oil. One might be thinner than the other depending on formulation, hence why it's a given range not an exact amount.
For example 0w30 German Castrol is 12.1 CST @100C. Another xxW30 oil might be 11.0 CST @ 100C. Still within the range of being a 30 weight oil..
