cam and stall
Old 10-26-2008, 09:55 AM
lt1formula275's Avatar
Exclamation cam and stall
im going with stock block and heads is there any cam u can use on an a4 that want require a stall converter
Old 10-26-2008, 09:58 AM
96capricemgr's Avatar
There are cams that are drivable without a stall but none that will really improve performance without a stall. I speak from experiance on this. I was afraid of stall I went with a mild cam, car was no faster. Once I began properly supporting the cam though ity woke up in a big way.
No need for you to repeat my mistake.
If this is a repair and you plan on later adding the stall something like the Crane 227(210/224) or Lingenfelter 211/219 with both drive well with the stock stall and will perform well once you properly support them.
