Who has deleted their oil filter bypass?
Just wondering if anyone else out there has deleted their oil filter bypass?
This is my current understanding of why auto makers use it per Wikipedia:
If you wait too long to change the oil and oil filter, there is a danger that the oil filter might become plugged. To prevent a plugged oil filter from starving the engine for lubrication, oil filters have a built-in safety device called a "bypass valve." When the differential pressure across the oil filter element exceeds a predetermined value (which varies depending on the engine application), the bypass valve opens so oil can continue to flow to the engine. But when the bypass valve is open, no filtration occurs.
The bypass valve also opens when a cold engine is first started. Cold oil can be fairly thick and may not pass through the filter element very easily. So the bypass valve opens and allows the oil to go around the filter until the oil warms up and flows more easily. During this time, any contaminants that are in the crankcase may be sucked up through the oil pump and bypass the filter, causing increased engine wear and possibly engine damage. Once the oil gets warm and the bypass valve closes, oil flows through the filter and normal filtration resumes.
I always change the oil properly so there will never be an issue with the filter plugging up. I simply want all my oil going through the filter.
Who else has done this? Who thinks it was a bad idea?
you dont need to buy anything. Take yours apart and there are 2 bolts that hold it on. There basically studded bolts. They screw into the block then the studs hold on the actual cooler. Well take everything spart and just cut off the stud part and just make it a reg. bolt. Bolt it all back toghter and your ready to roll. FREE MOD!!! I did it and it works just fine and not "redneck" at all, lol.
the bypass is built into the filter......some cheap *** filters dont have them.....oil goes into the filter period....but if its too thick or too dirty instead of it flowing throught the filter element and into the center of the filter and back up into the engine it will flow through the bypass in the filter....what type of ghetto redneck mod is this? dirty oil is better then no oil........leave it alone the benifits (i really dont see any) are no way near worth the risk......
i cut the dowels off the head of the bolt an d removed the cooler, then ran a piece of 5/8 heater hose as a bypass to the cooler. you can use a "non bypass" oil filter adapter from a SBC to kill the bypass.
