A couple of new bests-finally!!
I knew the car had a little more in it, but do to some set-backs it took a few trips to the track this year to sort things out. Made a couple of NA passes for a baseline, and then used the nitrous. First pass was a 10.93 at 122.88mph with a 1.49 60ft. Second pass lowered the on point from 3800rpm to 3600rpm and ran a 10.89 at 123.73mph with a 1.47 60ft.
Thanks go out to Larry at Speed, and Ion for helping fine tune a few things in the computer. Also got to see Larrys new 396ci in action, and was very impressed. I'll let him tell the details though. Here's to you Larry.
Edit: Forgot to mention, the new times are with the added 65lbs of weight, from the Wolfe 6 point.
Nice job on your new best. Good mph, just get that 60ft. down.
Actually, I'm thinking about some weight reduction. A little less strain on the poor stock trans and and this weak *** 10 bolt would probably go a long way, or not.
Congrats on the new best. I was there to trying to dial my car in with the 4.10's and bigger stall. My car will not cut a hard sixty for nothing I was running 11.20's on motor and my best sixty was a 1.59 the rest were all 1.6's
