will I have any problems welding this Bullet in place of the stock muffler?
Old 11-03-2008, 07:05 PM
MonmouthCtyLS7's Avatar
Default will I have any problems welding this Bullet in place of the stock muffler?
2.5 one ofcourse...
http://www.jegs.com/p/PYPES/1032950/10002/-1
Old 11-03-2008, 07:15 PM
ThreeHonks's Avatar
how do you plan on doing this since the stock muffler is single inlet/dual outlet?
Old 11-03-2008, 07:18 PM
davidadavila's Avatar
you wont i would suggest to get some cheaper ones from summit they are the same thing, if you are fabbing it up yourself than might as will go duals because you are going to have to do bends where your old muffler was....
Old 11-03-2008, 07:19 PM
Im looking to replace the muffler on the stock catback...any reccomendations
Old 11-03-2008, 07:21 PM
Super 44 Muffler In 2.50'' / Out 2.50'' (Dual)
That should work right?
Old 11-03-2008, 07:24 PM
ThreeHonks's Avatar
If you want to just have an easy weld/clamp on muffler I recommend a magnaflow single inlet/dual outlet. You need the magnaflow mufler part #12266. This is correct as long as you will be using the STOCK diameter piping
Old 11-03-2008, 07:25 PM
Thats what I needed thank you
ThreeHonks's Avatar
The daimeter of the stock tailpipes are 2.25"
