Help Tchain swap
Help Tchain swap
Just slid in my new cam and need help with Tchain. I called Comp Cams and they said 7136 billet double roller would work since I have an electric WP. Well issue is I need the opti drive and there is no keyway for the opti drive. I want to use this tchain setup.
I'm sure someone has had this issue. I don't want to buy an LT1 chain set. This is an early opti set up.
There isn't really much you can do short of switching over to the vented type opti. If the stock sprockets look good why not just get a new chain? They are pretty stout, lots of people run them. I ran one spinning 6800rpm with 140lbs of spring pressure on a 242/248 cam.
Ohh I can pull out the dowel pin?? Cool!! Just to make sure there isn't that much of a difference in dowel lenght?
Both cams are lt1 so there is a hole.
I want to use that roller tchain its much lighter than the oem set up.
So is it worth it? Opti crap is opti crap and I don't want to spend all that $$ on the LCC setup.
