Professional products thottle body
does any have a professional products throttle body? if you do can you tell me a little about the quality and if it sticks at all? im a little tight on money thats why im looking at this one.
Thanks
Thanks
I ran one for a while that was fine on a bolt-on car as-is, and after the idle air hole mod was fine with the H/C package. Did not ever stick on me and I did not have any complaints.
I changed to an AS&M basically for the "bling" factor since it is a trick billet piece instead of sand cast. It also needed the idle air mod as well, so performance and drivability wise they were identical, on difference being a few hundred bucks on the price tag!
fyi, as far as sticking, I've got a stock TB bored to 54mm and it sticks occasionally, it doesn't return all the way to the stop and the idle is like 2-300 rpms higher. I think it has something to do with one of pieces being painted.
