lt1 crank hub
lt1 crank hub
how exactly do u get that damn thing off? I have a 3 jaw puller and tried that with the bolt started in the threads. didnt budge at all.
Get a little rod that is 4 or 5 inches long (the rod needs to be smaller than the bolt so it can feed all the way through) once you have that in place if of the bolt, it should work. If that makes any sense what so ever..haha.
Be careful with the bolt, you might screw up the threading in the hub/the bolts threads too, just an fyi.
