High 11s Low 12s
Old 11-11-2008, 04:10 PM
th3brandon's Avatar
Default High 11s Low 12s
iam doing a 383 w the gm847 cam shooting for high 11s low 12s on motor...i have ported stock heads, yanks 3600 stall, mt drags radials,Lts w ORY, ect ect you guys get the point...do u guys think this goal is in reach...and wat r some pointers u guys can give me...i want to be somewhere around 400hp..
Old 11-11-2008, 05:49 PM
LT14LIFE JT's Avatar
You should be able to reach your goal of high 11s low 12s cam only, or atleast with a stock bottom end. If you haven't started the build, I'd recommend you buying a nitrous kit and holding off on the 383. Save yourself a few grand on the build and spray your way to high 10s and maintain daily driveability. Just my .02.
Old 11-11-2008, 05:54 PM
StealthFormula's Avatar
That will be capable of hitting 11's. My pointer for you with experience with the same Stall is to launch from about 1000-1200rpm. Launching from there has gotten me my best '60 times, just something to help you get a little better et when you do run it.
Old 11-11-2008, 06:35 PM
96autoformula's Avatar
A 383 with a decent amount of cam should be in the 450 plus HP range, so yes, high 11's with a decent stall and rear is very attainable.
Old 11-11-2008, 08:21 PM
th3brandon's Avatar
yea i was goin to do that but i blew my motor on the way down the track 4 miles from the exit ...so the 383 build is under way
Old 11-11-2008, 09:26 PM
CamaroRacing12's Avatar
least u didnt oil down the track
u will def get high 11's maybe mid to low 11's depending on raceweight
Old 11-12-2008, 02:45 PM
th3brandon's Avatar
wat size injectors do u guys think would work the best...i was looking at lucas 42lbs...anyone use these?????
Old 11-13-2008, 07:26 PM
mhissstic's Avatar
Id do suspenstion to as well to garuntee the best e.t.
Good luck with the build
Old 11-13-2008, 11:06 PM
tspence45's Avatar
You'll easily hit a high 11 in a 383 with a GM847 and ported heads. If you can drive, you could hit that in a cam-only, stock displacement LT1, with a decent enough cam.
Old 11-14-2008, 10:50 AM
Z-RATED94's Avatar
Small cams can get it done too. Stock block, trans, and rearend. It has some suspension pieces but sits on Eibach Pro lowering springs and stock shocks. Gotta love those MT street radials. 12.0xs in the heat, and low 11.9xs in good air.
Old 11-14-2008, 11:04 AM
joeZ96's Avatar
Rick - What are you running for a torque arm and lower control arms?
Old 11-14-2008, 11:20 AM
Z-RATED94's Avatar
Spohn chassis mounted adj. TA, tied into KBDD subframe connectors. Set at minus 1 1/2 degrees pinion angle. Lakewood control arms with welded relocation brackets set at the lower hole.
Quick Reply: High 11s Low 12s
