putting cam in this weekend: need advise
I have pretty much all the parts I need to do my cam swap this weekend, with the exception of pushrods and rocker arms.
I am doing a very mild cam swap using the comp cam cc07-500-8. I also purchased the comp cam valve spring set (retainers,keepers), lifters, timing chain set, valve covers (w/alt clearence), intake mainifold (58mm ported), 58mm throttle body, and of course all the gaskets, pullers and oil.
My question is, are these comp cam high enery pushrods (7.195" length/5/16" diameter) the right ones for my 96' LT1? http://cgi.ebay.com/ebaymotors/COMP-...QQcmdZViewItem
Also these rocker arms? http://cgi.ebay.com/ebaymotors/COMP-...8986QQtcZphoto
Will those rockers clear my valve covers? And are those valve guides pictured?
just get it from summit. similar prices and its guaranteed. unlike stuff from ebay but yes theyll work these are what i just bought
http://store.summitracing.com/partde...6&autoview=sku
http://store.summitracing.com/partde...0&autoview=sku
but if you get the non self aligning rockers youd need guideplates
http://store.summitracing.com/partde...8&autoview=sku
Roller tip is pointless.
I would not bother replacing the pushrods with such a small cam unless you do use non-SA rockers and guideplates and then I would only replae the pushrods because of the guideplates.
I put a ZZ4 cam in my car at one point, was a little bigger than the cam you are looking to do, and even in this big whale of a car with 1650 stall and 2.93s it was fine, mistaken for stock by most folks who were around the car. After my experiance with that I think the Crane 227(210/224) is the smallest cam worth the effort to swap in. Like I said this is based on my experiance and that is with a car that would be much more sensitive to cam size.
I decided to go with this cam because it does not require the computer to be flashed (summit tech told me). I am building this car while I am in school, so I want to be able to do all the work myself in my garage. I figured I would replace all preventive maintence parts, so I bought these parts today and like said before the lifters, springs and such. I am pretty much giving the engine a nice tune up
