Coolant Smell
Coolant Smell
Usually when driving my car around I'll get a coolant smell every now and then. I have yet to see the car leak any anti freeze though. Any idea what it could be?
Moderator
Mines has been doing the same thing, I plan to rent a tool to pressurize the cooling system and go from there when I get home and have some time. I even had the shop who did my gear install try and find it after I couldnt find it and they couldn't find it either. Annoying as hell
I know my hoses are tight. My window doesn't fog up when i turn on the car but maybe it is my heater core. my heat works crappy but i think thats becasue of my 160 tstat.
I get a smell too when hot and I have pressure tested the system only to find a small drip. I put another turn on the hose clamp and it stopped it (new hose/ clamp). I still have the smell though and its losing coolant. Hope its not another head gasket.
just go to autozone, and rent a pressure tester. Tell them you want a radiator pressure tester. It's around 70 i think, i can't remember there not the greatiest. Take about 3 or 4 attempts to check the pressure if you here air blowing of its not sealing up properly, it seemed they weren't very good for f-bodys, but you'll find the leak
It could also be coolant seeping out of the weep hole on the bottom of the water pump. When it hits the engine it burns up and that's why you smell it. If thats the case you probably want a new water pump and maybe an opti.
I have that smell turns out its a small leak (not all the time though) but it was at the bottom of my radiator core on the inside facing the engine. I found it cause it sprayed the back of my air dam. So now i got to find a radiator
