Remove AIR pump?
Remove AIR pump?
Hey I put long tubes on and i just ended up capping off the air and EGR stuff. someone told me i could remove the AIR pump. is this true? im just trying to figure out what i can remove before i do it so i dont **** anything up lol
I took everything associated with my air pump out. Metal line under the motor also. Only thing still there in the electrical connector hehe. Spare parts, give er' !
Yes you will need to cap off the line that goes from the air pump into the cai intake tube. There is also a small fitting on the inatke manifold that has two vaccum fittings coming off of it. Trace all the vaccum lines from this and pull anything off that connects to it. One line will lead to the air pump in the front of the engine and the other will lead to the rear (near the egr) pull all of this off and you are just fine. I will take pics of what everything looks like for you if I can get my camera to work
