Power loss from incorrect valve train geometry?
not sure if I should be posting here or advanced, so I'll try here first. I am not totally sure if my valvetrain geometry is correct, but plan to check it out in the next month or so. I don't think it's right becuse the heads were milled and i was told to use stock length pushrods, Also using the felpro gasket which is thinner than stock. anyway, i was just wondering how much power I could possibly be losing (if any) from the pushrods being either too long or too short?
I have some dyno numbers, but the problem could also be in the tune. i got got 295/314 on a mustang dyno. with the mods in my sig, I would hope to put down more than that, and valvetrain is one of the things i think is contributing to my lack of power.
The tune is what I would consider the equivelant of a mail order, I got it on another forum from a user claiming to have the same modifications as i do. I know that is kinda a hit or miss way to go about tuning, so I plan on having the car actually dyno tuned this winter as well, but I am hung up on whether I should do a full dyno tune, or just a WOT tune, the full dyno is about $150 more hence my dilemma.
The car drives fine, nothin really out of the ordinary, except for some cam surge down low and a very very slight vibration, but I think it is normal
In your sig it says "worked heads". Were the heads dones buy a reputable porter? and did you get flow numbers? I had a set of heads done a few years ago by a supposed cylinder head genius, did all kinds of R&D for ford and GM in the 80's. Definately knew what he was talking about but when it came to porting my heads they turned out like crap. He said 270cfm, they flowed at 230 on two different benches.
