cut thumb open need advise
I am currently putting in my cam and realated parts. I removed the spark plugs to change out the valve springs using a cylinder compressor. After re-installing spark plug number 2 I noticed a very fine (1/8") crack on the insulator. This crack is covered by the boot and I put a good coat of electric grease in the boot to prevent any moisture or dirt from entering the core. (until I can get a new one.)
Later I was cleaning my gasket surfaces with a razor and my sister distracted me, resulting in my thumb getting sliced wide open. My concern is more on the spark plug then getting stitches though.. I used my left hand (thumb thats cut) to put the spark plug in and I couldnt get my right hand inbetween the strut tower and head/exhasut.
If I have a mis-fire in cylinder 2 I am wondering if I will be able to access the spark plug with the engine back together and my thumb healed? Any special way you guys normally go at it?
I seemed to have the most difficulty with cylinder 2's spark plug.
I tried to reuse the old ones (they are fairly new). If I do get a misfire I will just replace them all because im sure if that one had a fine crack on it, others would too. I would swap the one out now but I barley got it in with my hand in one piece, I cant see myself getting it in easily, so it would be in my best interest to wait for my hand to heal and replace them all.. IMO.
I tried to reuse the old ones. If I do get a misfire I will just replace them all because im sure if that one had a fine crack on it, others would too. I would swap the one out now but I barley got it in with my hand in one piece, I cant see myself getting it in easily, so it would be in my best interest to wait for my hand to heal and replace them all.. IMO.
also take note on the angle the plugs are set in the head. thatll go a long way and save you time on guessing. heres somewhat of a description.
...firewall....
/8 \7
\6 /5
/4 \3
\2 /1
...firewall....
/8 \7
\6 /5
/4 \3
\2 /1
Reaching plugs can be a bit of a pain.
I generally reach 2,4 from the top and 6,8 from the bottom.
It can be easier if you remove the alt or starter. (both easy to do, just remember to disconnect the battery first)
The thumb is doing a lot better, almost healed with no stitches. I have been using a **** load of cut ointment.
The start up went fine and only threw one code for having the cruise control cable a little too tight (RPM too high at idle P0 507), but I adjusted that and erased the code. Since then no code, *knocks on wood*. Like I said the crack (if it was a crack) was very very small.
Here is a teaser picture until I get the others uploaded:
Wow your engine compartment is looking clean as hell, and its red so the blood will blend in... The comment about the super glue is right on, I hate to say it buy I've worked in an ER and its very common for them to use superglue on lascerations, esp finger or other things that flex and move.... just get a brand new bottle clean the cut out first with hydrogen peroxide and have at it.... Otherwise good lookin out guy....
