stock bottom end-nitrous-cam
Old 12-01-2008, 01:32 PM
ElkySS's Avatar
Default stock bottom end-nitrous-cam
will the stock bottom end handle a 150-200 shot of nitrous plus the cam in my sig shifting at 63-6500?
Old 12-01-2008, 01:37 PM
Elliott's94Z's Avatar
It prob would but for how long is the question...I would prob stick with a 125 or 150 shot to ensure longer life. Just be sure your not spraying from the dig and make sure you get all the safety features that go along with whatever Nitrous kit you go with. I would rec the Nitrous Outlets wet plate set up.
Old 12-01-2008, 01:41 PM
kinglt-1's Avatar
It should, but make sure the tune is spot on!
Old 12-01-2008, 01:52 PM
ElkySS's Avatar
i guess ill stick with a 150 shot. even tho i really wanna go bigger. im guessing it would help to get a high volume oil pump and bigger oil pan?
Old 12-01-2008, 02:13 PM
Your gonna want to replace the fuel pump, injectors, spark plugs to the TR6's and have the timing adjusted as well with a 150 shot
Old 12-01-2008, 02:27 PM
ElkySS's Avatar
i already have tr6s, 30# injectors, and ill have it tuned wen i get the nitrous. will probably add a 6a box too
Old 12-01-2008, 02:30 PM
GoFastKid's Avatar
+2 on the fuel pump! Mine went shortly after I installed mine. Should have just listen to Elliott in the begining when I had it installed Be sure to get the window switch and any other safety stuff
Old 12-01-2008, 06:54 PM
slomarao's Avatar
shifting at 6500rpms with a 150 shot will end the motors life in a season or two. You cant rev it to the moon and hit it with juice. Pick one or the other but not both. Well, for any amount of time. I would consider a 125 shot if your not rebuilding it soon.
Old 12-01-2008, 07:03 PM
kinglt-1's Avatar
If you want to add a stand alone fuel system for the nitrous, you could run a 250 shot. I know of a guy that is running a 250shot on a stock a4 lt1, it went 11.80. It only had a catback, no ****! But he had a seperate fuel cell and pump for the nitrous. I would not spray a stock lt1 that hard personally, but it has been done.
Old 12-01-2008, 07:51 PM
foggedz's Avatar
If it only went 11.80 it wasnt making an extra 250HP. Should have went faster than that, and probably wouldnt lasted more than a few passes. That is if it was actually seeing and extra 250HP.
Old 12-02-2008, 11:11 AM
Z-RATED94's Avatar
Times in sig. LE heads, small cam, Nitro Daves plate kit, running about a 130 shot. Somewhere around 480-490rwhp. Shifting at 6200 so that the stock shortblock, trans and rearend last a little while.
Old 12-02-2008, 12:42 PM
kinglt-1's Avatar
Just because its a 250 shot does not mean it's going to pick up 2.5 seconds. It ran 13.8 off bottle 11.8 @ 118 on. Pretty good run imo. also it has been sprayed multiple times at the track and on the street. Still I would not spray a stock motor that hard, but it can be done!
Old 12-02-2008, 01:21 PM
speed_demon24's Avatar
I had a friend putting 2 bottles through his car a week on a 175 shot cam only LT1. The motor took it fine, but it finally let go when a valve seat dropped from shitty headwork.
Old 12-02-2008, 04:18 PM
blackz93's Avatar
Keep the RPMs down.
Old 12-02-2008, 06:00 PM
96capricemgr's Avatar
Bigger jets does not always mean more power. Watched an acquaintance swap from 175 to 200hp jets on a heads/cam car and the car went no faster.
A friend sucessfully used 150-175 for a couple years on a heads/cam stock shortblock setup but number 1 piston gave up in spectacular fashion when he tried 250.
The stock pistons and ring gaps are not meant for this stuff and it is possible to overheat them butting the ring gap and ripping the ring lands out of the top of the piston.
A high volume pump is not going to help, high pressure might but high volume without changing bearing clearances just means more oil bypassed within the pump, never going anywhere to do any good.
Old 12-02-2008, 06:22 PM
kierstyn's Avatar
One of my friends had this happen to his when he tried a 200 hit of TNT on his stock bottom end. The ring gap closed up and cut the top of the piston off! It trashed the whole motor heads and all!
Old 12-02-2008, 06:43 PM
Moderator
BizZzatch350's Avatar
You may want to try and dial the fuel jet in with a wide band. Thats what I planned to do with mine, still have the thing, never got a chance to install it or get the gas working. We had a 97 Z28, with a who knows what done tune. We put the car on a wide band and progressivley bumped the jetting up paying attention to what it was doing when we were spraying, adjusting the fuel jet as we went. You may want to do similar
Old 12-02-2008, 07:24 PM
ElkySS's Avatar
that sounds pretty interesting. ill look into that when i get more serious about it
Old 12-03-2008, 02:04 AM
robsquikz28's Avatar
id say up the pump to 255 and fuel injectors to atleast 36 or 42's and u can go up to 175 with a good tune i have done it with 2 cars they lasted for along time too..
Old 12-03-2008, 09:20 AM
ElkySS's Avatar
lastED? what do you mean lasted? u blow them up or sell them or what?
Quick Reply: stock bottom end-nitrous-cam
