Subframe Connectors What do you have??
Old 12-02-2008, 02:47 PM
SpeedDensityZ's Avatar
Default Subframe Connectors What do you have??
What is the best subframe connectors for our cars. Hardtops.
Old 12-02-2008, 02:54 PM
1badzee's Avatar
I'm goin with UMI
Old 12-02-2008, 02:55 PM
Elliott's94Z's Avatar
Not sure about hardtops, but I'm running the UMI 2 point bolt on SFC's and they def made a noticeable difference. Great quality and pricing as well. I plan on welding them in at some point.
z28rob18's Avatar
im goin to use bmr the boxed ones look real stiff
Old 12-02-2008, 02:59 PM
Yeah, I've been looking at alot of them. Is there an advantage to the spider web looking connectors? (UMI, SLP, Double Diamond, Kenny Brown) I already havea tunnel mount tq arm in the center that uses the old brace bolt holes.
Old 12-02-2008, 03:05 PM
camar0corey's Avatar
Running the SLP double diamonds. If running a torque arm like that I would run the SLPs, it helps stiffen that area up.
Old 12-02-2008, 03:06 PM
JB_97ws6TA's Avatar
UMI 3 point SFC's, get the bolt in drive it around to make sure that nothing interferes than have them welded
Old 12-02-2008, 03:11 PM
96lt1m6's Avatar
Tubular BMRs
very nice,easy instal.
i am sure the other are as well
By spider web do you mean the 3 point style that connect not only the front and rear but the middle as well?
Old 12-02-2008, 03:14 PM
http://www.umiperformance.com/2003?category_id=129
This is one style of the web I would recommend
Old 12-02-2008, 03:38 PM
Yep, the correct name escaped me at the moment.
Old 12-02-2008, 03:41 PM
brynnda's Avatar
i dont really have an opinion on brand, tho this is something i plan on getting in the future so any advice for me would be great too, ive heard weld on, not bolt on is the way to go??
Old 12-02-2008, 04:01 PM
StealthFormula's Avatar
I run bolt-in UMI tubulars and they are awesome. Can't see them from the side of the car which is why I went with tubular over boxed.
Old 12-02-2008, 04:04 PM
lutzfire24's Avatar
Originally Posted by 1badzee
i'm goin with umi
x6....
Old 12-02-2008, 04:16 PM
Racin96ss's Avatar
I'm running BMR boxed and like them. UMI or BMR you can't go wrong.
Old 12-02-2008, 04:24 PM
Hammbone's Avatar
im t-top but running Weld-in BMR boxed.
Old 12-02-2008, 04:34 PM
Bad_tx_Z28's Avatar
should hardtop cars even bother with SFC's??
Old 12-02-2008, 05:26 PM
AChotrod's Avatar
Yes^^^^^ Im running BMR tubular weld in hardtop connectors. Cant see them unless you start looking under the car.
Old 12-02-2008, 05:32 PM
LM97Z's Avatar
Any unabodied car will benifit from SF connectors, HT or TT, HTs have a stronger roof construction, but the car is still a unabody.
I bought the BMR Tubulars & they are indeed very strong & nicely built, cheap in price too.
Old 12-02-2008, 05:34 PM
LM97Z's Avatar
There sweet ain't they
Quick Reply: Subframe Connectors What do you have??
