Is this typical?
Old 12-04-2008, 05:43 PM
nik1703's Avatar
Default Is this typical?
I have 275's in the rear... coming from an E36 M3, that's pretty damn wide.
But for some reason I have ZERO traction in first gear. Off the line... from a roll, or even at a 4k RPM roll, it just spins the tires. Second gear and on i have traction.
So.. looking at the mods in my sig, is the typical? What size would you guys recommend and do you think i'll need different rims?
Old 12-04-2008, 05:49 PM
cammed93TA's Avatar
with those LCA's you should get some... you have to remember there is a lot of power going to those rear wheels...you can't just floor it and expect it to stick. DRAG RADIALS!!!
Old 12-04-2008, 06:08 PM
Elliott's94Z's Avatar
Looks as if you have the suspension part mostly dialed in...it really comes down to tires now. I would suggest putting some nice Drag Radials on. The Nitto NT555RII would be a good upgrade.
Old 12-04-2008, 06:13 PM
nik1703's Avatar
http://www.onlinetires.com/default.a...ails&tid=31614
How do these look? will they fit my rims? And how is the price on these?
Old 12-04-2008, 06:15 PM
What is your current set up? Wheel size etc etc..then I can help ya
275/40/17??
Old 12-04-2008, 06:18 PM
nik1703's Avatar
275/40/17??
275/40/17 - yep. But i have some really cheap tires. I forget the name, sumutimo or something. Came with the car. I mean, they're in brand new condition... but they are about 5 years old and the rubber doesn't even squeal when you spin the tires because the car was sitting for 5 years.
Old 12-04-2008, 06:24 PM
Yeah I have new tires as well but they don't grip worth a damn! I could lay a strip up the entire 1/4 mile if I wanted.
Sumitomo's are cheap tires...did I mention cheap? They work for getting you to point A to point B. Anyways, yes those Nitto NT555's will work . Obviously you will need 275/40/17. They ran me 162 a tire. Most places will be a bit higher. I played the pricing game America's Tire Co sold me mine.
Old 12-04-2008, 06:28 PM
What I did is kept the front 2 tires and just bought a set for the rear. I don't drive it much so they should last me a while. What I would suggest doing is, grab a video camera and burn the back tires down to nothing then post the video up and then install the Nitto's in the rear...lol
Old 12-04-2008, 06:32 PM
nik1703's Avatar
that's where i'll be getting mine if i don't order them online. they are cheap considering they're expensive tires. So you think the NT555RII's (275) will hold me down?
Old 12-04-2008, 06:35 PM
Sure as heck will help you over them Sumitomo's that's for sure!
Old 12-04-2008, 06:37 PM
nik1703's Avatar
sweet. I'll just burn up these sumitomo's and then slap on the nittos. Thanks for the advice! They're pretty cheap too
cammed93TA's Avatar
+1 I had 555r's on my 99 ss 6 speed and let me tell you its night and day...
Old 12-04-2008, 06:41 PM
Yeah the new 555II have been re-designed for better handling for road racing, cornering so on...
Old 12-04-2008, 06:53 PM
That's MISTER MODERATOR
Paul Bell's Avatar
I was running the BFGDR's but they're lifespan is so short, I was going broke buying them, even when I "took it easy" on them . I tried the Sumitomos and while they've considerably outlasted any set of drag radials I ever had, they certainly don't have traction when I get into it.
I do think the Sumitomos have better grip in the rain. And less than a hundred bucks for the 315/35/17 size!
Old 12-04-2008, 06:56 PM
nik1703's Avatar
Yeah, well the sumitomos have less rubber on the ground then the nittos or the bfgdr's. I'm gonna go with the nittos, they can still be driven in the rain
Old 12-04-2008, 06:57 PM
Yeah I hear them BF G's lifespan suck something bad
Old 12-04-2008, 07:08 PM
cammed93TA's Avatar
just be ready to hydro-plane with any DR's hahaha...I love it, cause most people don't know how to drive with regular tires...but here I am going 70-75 down the freeway with DR's lol
I love the nitto's, but the BFG's look so much cooler
Old 12-04-2008, 07:32 PM
Formula350's Avatar
I won't deny my DRs don't stick the best in wet conditions, but I was DAMN surprised at how well they did. It took a fair amount of water on the road for me to finally experience some rear and hydro action, and it was on the highway. Which, isn't exactly good heh, but slow speeds even with me getting on the gas, I kept traction. Moist roads or mist/light rain isn't much of a problem. I'm running M/T drag radials in 255/45R16.
I have some Goodyear Eagle GS-C's that'll be going on for winter once I get my trans done. No, I don't WANT to drive it in the winter, but I have to. Once the trans gets back in, parents are selling their POS 02 Protege (horse **** in the rain and 10x worse in snow) and so I'll be giving up the 'Yota Crapolla
Old 12-04-2008, 08:17 PM
camerory's Avatar
Yeah BFG's are rated at something like 3000 miles before they are toast and the Nitto 555r's are about 10-15,000 miles based on average driving. Somebody correct me if I am wrong.
Old 12-04-2008, 08:48 PM
I have heard that about BF's. The Nitto's are rated at that you are correct on that one.
Quick Reply: Is this typical?
