high rpm wot cracking noises
i picked up my lt1 today it runs great but under high rpms it cracks and makes pop corn popping noise from under the hood and shakes around. car has 158,000 its a 94 z28. The car is throwing no codes is this a bad opti?
i let the guys at work drive it they seem to think its hitting the rev limiter because it hits 5,500rpms in first gear stays there then goes pop pop pop until u left of the gas wot. old owner said it has a shift kit i work at a trans shop they seem to think the 1-2 shift point is higher then the limiter? still doesnt explain why it runs badly at 4,500rpms
nope cant even manually shift it will start to run shitty starting at 4500rpms then it struggles and shakes to 5500 and just sits there and jerks and pops badly if i hold the pedal it just stays at that rpm and doesnt shift when i left of a puff of black smoke will come out the pipes. Other then wot this cars runs beautiful it looks like oil is leaking in my opti i wonder if this can cause this also i took my hand and beat the cat and you can here the catalyst broken up in the cat. popping sounds like its coming under the hood and out the exhaust goes away as soon as i let of the gas
now that you say that i'd double check to make sure its a bad cat, if it is then replace it asap, if you dont the cells might fuse together and the exhaust gets so back up it blows up your engine.
