opti?
Old 12-10-2008, 06:11 PM
383Z-28's Avatar
Default opti?
would a burned spark plug wire cause an opti to blow out
Old 12-10-2008, 06:23 PM
StangeatinZ28's Avatar
i seriously doubt it
Old 12-10-2008, 07:21 PM
redhot lt-1's Avatar
no i dought it to the stock opti is not set up to turn high rpm`s if you are running it often. i had the same issue`s 3 years ago i got one from http://www.delteq.com/opti_design.htm and not looked back. they have from what i`ve heared stop making the replacement opti but i know MSD now has them
Old 12-10-2008, 07:46 PM
383Z-28's Avatar
is that just a bolt in kind of thing or is it real hard to put in
Old 12-11-2008, 10:35 AM
no it pretty strieght forward i got real good at it i could swap out the old OEM opti in less than a day but the instructions from delteq made it easy for the opti distrubitor swap. the LT1 OPTI-DIRECT IGNITION SYSTEM i`ve never done but from what i`ve heared as long as you get the complete install pack it shouldn`t be that hard
Quick Reply: opti?
