Anyone Runnung this cam ?
Its the Comp Cam Part # is Com ko7 466 8
1800-5800 rpm
Adv Dur 268 int/ 276 exh
V lift 570 int/ 565 exh
Lobe 113
Just wondering what kind of #s it makes and if it would work well in a stock motor ? Thanks
Michael
1800-5800 rpm
Lobe 113
Michael
I ended up with that cam based upon the recommendation of the Comp Cam tech dept. where I had asked them to give me a cam which will give me 50 additional HP without upgrading the heads. They said it would need full exhaust, which I have in spades, along with a tune, which I got form PCM -For-Less.
The car runs like a rape ape. With all of that listed in the sig, I picked up well over a full second ET in the 1/8th. Pre-rebuild I was in the mid to low 9s on 20" steel rims with Falken radials. Adding a new set of MT ET Streets, she pulled an 8.03 last Friday night. It was one of those nights at the track where it seemed like every ricer was spraying hard and blowin' their motor, so I only got 8 or so passes. I expect to see her into the high 7s tomorrow night.
So yeah, I'd recommend it on a stock engine, given the above noted mods...
What would you be running in the 1/4 ova1. Thank you for ur reply
Elliott i am just trying to add alittle hp with out killing my bottom end, I am gonna buy it as a cam kit it comes with Valve springs Etc... I know i will need a Stall and full exhaust and a tune when im finished modding. Im just trying to find a good cam with decent power gains. Thanks for ur reply
http://www.elliottsportworks.com/lt1.html
I called out there one time and left a message and no one called me back so i was like screw it. Ive seen alot of good stuff from there tho, What kind of #s is ur car putting down?
DAMN! Lloyd raised those head prices by 1-2 hundred bucks since i was last on... and that was about 2 months ago... i wonder why?
anyhow i would definently consider elliots or at least try to call them again... you may want to email him this time...
I know when i first got my 93 i was considering getting heads and cam for it his prices were alot cheaper. I will give him a call again a see what he has to say, Thanks Everyone
i'm 99% sure that le1's were 800 heads, 1100 heads-n-cam
le2's were 1150 heads, 1450 heads-n-cam
le3's were 1450 heads, 1750 heads-n-cam
i used to have the prices saved somewhere...
intake porting did remain the same...
i know they definently went up... could be because of rarety
Now it's on my 383 stroker and making good power (sorry no dyno yet) but I may go with this next
Comp Cams #249-07-467-8
# "XFI" 280 Hydraulic Roller CamshaftGM LT1 & LT4 350ci 1993-96
Lift: .576"/.570" w/1.6 Rockers
Duration: 280°/288°
RPM Range: 2000-6000
