Iron Vs. Aluminum
Old 12-17-2008, 08:00 PM
1slo_camaro's Avatar
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
Default Iron Vs. Aluminum
i was told by someone that iron flowed better then alum. stock for stock. can someone please clarify this for me and show some evidence please
Old 12-17-2008, 08:09 PM
Mighty Whitey's Avatar
that seems to be the info I've got. basically for the reason that a thinner iron casting will hold up better than a comparably thick aluminum piece.
why a 3/8plate of steel is probably as strong as a 3/4 plate of aluminum.
Old 12-17-2008, 08:14 PM
COPO9560's Avatar
Assuming the heads are ported the same, flow should be the same as well. The key difference between iron and aluminum is heat transfer out of combustion chamber. Aluminum transfers heat out much faster, resulting in less combustion temperature and pressure. Not a big difference but on older engines you should increase compression ratio when moving to aluminum to maintain same power. Aluminum blocks can have a similar impact.
Old 12-17-2008, 08:27 PM
danhr's Avatar
I believe the OP is more specifically comparing the lt1 iron heads to the aluminum lt1 heads.
IIRC, the iron heads flow about on par with unported 561 heads, and they flow better than unported 653's.
The 653's have a lot more meat to port though, and are more sought after by head porters.
Old 12-18-2008, 07:00 AM
96capricemgr's Avatar
Basically the iron heads were designed a couple years after the early aluminum ones so they had the advantage of a little more R&D, in 96 the aluminum heads fiaally flowed asmuch as the irons BUT are a thin undesirable casting.
For porting the 95 and earlier aluminum heads are most desirable despite the fact they flow the least as cast.
If the irons are heavily ported they can crack since cast iron is more brittle than aluminum, seen a few guys have trouble with this, not a lot but a few.
http://www.fierolt1.com/lt1_lt4_headflow.htm
Old 12-18-2008, 07:41 AM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
It's my understanding the Aluminum LT1 heads were designed first. The Iron ones spent a little more time in development and stock vs stock have slightly better airflow.
Old 12-18-2008, 03:54 PM
Taubr Unit's Avatar
good to know i have the better heads to port for stockers
Old 12-18-2008, 04:02 PM
GIZMO's Avatar
Sorry guys, but I have flowed quite a few sets of bone stock aluminum LT1 heads and the 1996-97 561's are by far the worst.
Old 12-18-2008, 04:10 PM
malibuwagon's Avatar
Default LT1 Heads
The reason alum lt1 heads where on the hi po engines was that u can run higher compression without detonation...so more power Jim
Old 12-18-2008, 05:17 PM
GIZMO, first I have heard that, but I trust you over most sources.
malibuwagon I think you are oversimplifying things with 60s era mentality.
Old 12-18-2008, 06:22 PM
GIZMO's Avatar
Originally Posted by 96capricemgr
GIZMO, first I have heard that, but I trust you over most source.
Believe me, I was highly disappointed after spending $1,500.00 to blueprint a set of $400.00 heads that slowed my car down! I actually went out and purchased more just to see if I had a "bad" set. None were as good as the earlier castings. If someone has actually flowed a "good" set, please post your results. The late model intakes are an upgrade over the 1994-95 intakes (don't expect a big gain).
Quick Reply: Iron Vs. Aluminum
