Best place for true duels for LT1?
Old 12-20-2008, 10:16 PM
B4CZR2's Avatar
Default Best place for true duels for LT1?
Looking to get a new exhaust and want true duels this time...
Old 12-20-2008, 10:42 PM
StealthFormula's Avatar
Best place to have them done? If thats what you mean TT Performance in Little Falls, NJ did a great job with mine and are a sponsor here. They are outside NYC if you happen to be near there.
Old 12-20-2008, 11:27 PM
B4CZR2's Avatar
Thanks but I live 400 mi away so unless they make a kit and can ship I need to find someone local. Watched your vids on you tube, Car sounds bad ***, looking to eventually go with a similar setup.
Old 12-21-2008, 12:43 AM
Thanks man. As far as I know for the LT1 there is no kit you can buy and just bolt up unfortunately. You should be able to find someone local who could fab one up tho.
Old 12-26-2008, 09:57 AM
B4CZR2's Avatar
Yeah much what i was afraid of. Don't understans why TSP doesn't have one, can't be all that diff from an LS1. Thanks for the insight, I will have to find a good exhaust shop around.
Old 12-26-2008, 10:03 AM
duff man's Avatar
I think the Texas Speed LS1 kit can be modified to fit our cars pretty easily, but it won't be a bolt on thing. Also be aware that if you have or plan to add a tunnel mount torque arm that it will affect where it has to be run.
Old 12-28-2008, 08:30 AM
multmigs's Avatar
If you have LT headers already installed the TS kit should be fine for you with some minor fitting, just remove your Y pipe and the catback you have now.... There's generic kits avail on both summitracing.com and jegs.com
Old 12-28-2008, 11:21 AM
3rdgen92maro's Avatar
i just bought a summit 3in universal xpipe kit and did slight mods to it to make it fit. all it all it was pretty simple an exhaust shop could do it with no problem.
Quick Reply: Best place for true duels for LT1?
