96 lt1 help
Old 12-28-2008, 03:17 PM
MadMike96's Avatar
Default 96 lt1 help
Will my car throw a code if i cut the converters off and weld in a pipe, I have to pass emissions here. Thanks to anyone with info
Old 12-28-2008, 08:09 PM
MadMike96's Avatar
Thanks .....
Old 12-28-2008, 08:13 PM
SoxXpupPeT's Avatar
if its OBDII (i think so) it will
Old 12-28-2008, 08:23 PM
robsquikz28's Avatar
yes it will unless you get o2 simulators or get the rear o2's tuned out from the pcm
Old 12-28-2008, 08:27 PM
cgroh89's Avatar
Yea youll throw converter efficiency codes
Old 12-28-2008, 08:45 PM
crookedbowtie's Avatar
Pull the cats...knock out all the junk from the inside. Add 3 bolt flanges to to the ends bolt them back in, leave the rear o2s in just tune them out. It will pass a visual and you may be able to tune it to pass emissions too. Or make a tube to bolt in place of the converters, and pop in the cats and stock tune before a test.
Old 12-29-2008, 09:53 AM
MadMike96's Avatar
So i really cant do nothing until i get a tune, if i gut them like crookedbowtie is talking about will it throw codes ? Thanks Everyone
