I think I figured out why I couldn't launch my car
Old 12-28-2008, 06:20 PM
speed_demon24's Avatar
Default I think I figured out why I couldn't launch my car
This clutch only had 30K miles on it tops too. I still can't believe how bad it is.
And the replacement
Old 12-28-2008, 06:24 PM
99problemz's Avatar
What kind of clutch are you putting in now?
Old 12-28-2008, 06:26 PM
Ram powergrip HD.
Old 12-28-2008, 07:02 PM
zlicious94's Avatar
I tried to put that clutch in with the stock flywheel and and wouldnt go into gear? Called ram and they said that that clutch has to be used with a ram billet flywheel?? Good luck!
Old 12-28-2008, 07:19 PM
The flywheel doesn't have any effect on clutch engagement/disengagement issues.
Old 12-28-2008, 07:24 PM
95firebird5.7's Avatar
why did ur clutch do that?
Old 12-28-2008, 07:38 PM
Green3spd's Avatar
WTF.. Speed Demon.. I plan on goin with that clutch so let me know how it goes!
Im gettin the Powergrip.. not the HD
Old 12-28-2008, 07:48 PM
AChotrod's Avatar
MAn... I could pull a 1.2 60ft on that old clutch.............
Old 12-28-2008, 08:07 PM
I have an adjustable master cylinder so I'm sure I wont run into any disengagement issues.
Old 12-28-2008, 08:11 PM
SoxXpupPeT's Avatar
i have that ram. its a nice piece. unfortunately with my **** *** luck theres now oil covering it from my intake
Old 12-28-2008, 08:29 PM
lt1z28camaro's Avatar
I used spec billet steel flywheel with the HD I'm pretty sure ram only made aluminum flywheels for lt1's.. I like the HD it grabs well, takes some getting used to at first though. What clutch were you running OP?
Old 12-28-2008, 08:32 PM
Mcleod single disk with an SLP PP.
Old 12-29-2008, 09:57 AM
Tireburnin's Avatar
Changing clutches on an F-body sure is fun. =)
Glad to see you are making progress.
Old 12-29-2008, 01:14 PM
Kevin97ss's Avatar
30k miles but how many launches? Do you ride it out or just dump?
Old 12-29-2008, 01:26 PM
Not too many launches, maybe 25 passes at the track on nittos. This clutch could never take any amount of heat so a quick release was all it ever saw, the best 60 ft was 1.9x
Quick Reply: I think I figured out why I couldn't launch my car
