LT1 Nitrous Build
LT1 Nitrous Build
Im building a bottom end for my lt1. I was wondering if anyone on here is running a 200, 250, or 300 shot on the stock crank? I have a 355 in mind if anyone has any input it would be great.
From what I've studied, it seems that as long as you pair the crank with 4 bolt mains that you could run around 600-750rwhp. I could be off on my numbers but it appears that above 500rwhp it's actually the 2 bolt main that becomes a bigger concern than the crank breaking. Chime in here fellas...
has GM ever produced weak *** internals? im pretty impressed with teh LT and LS internals anyhow. my stock crank too 500 Ftlbs to the tires a LOT! and that was clutch dumps on slicks at the track... my faith is good
as others have said it's not the crank it's the 2 bolt mains that won't hold up to the 300hp hit..... It might but chances are you'll hurt something..... as long as you keep the crank stable and not walking around within those weak *** 2 bolt caps you'll be good..... which is why most at those power levels go 4 bolt mains...... why not just buy a crank. A good forged crank is like what 700-800 bucks????
how much is a rebuild gonna cost if it splits the block in half when the crank or caps let go???? more than that....
On the list of the fastest LT1's theres a guy with a 355, 300 DP shot, Stock crank. Hes running high 9's @ 139ish i think. Hes not the only one doing this kind of thing. There are lots of people making big numbers with FI setups.
Well Im not trying to say the stock crank is a good choice. I would put a forged one if it were my motor but im just trying to say that many have done insane things with one.
I would also guess that it had 4 bolt mains. And i dont think it lasted too long given what the guy was doing. But props to him.
