Money Decisions
Old 12-29-2008, 09:18 PM
Bad Lt1 Camaro's Avatar
Default Money Decisions
Got about a $1000 to work with just got in a magnaflow catback, already have MAF and FIPK...got 105,000 and i cant decide on what to spend money on that will make it worth it. IM NOT TRYING TO BUILD A 10 SECOND CAR, MY 13 SECOND CAR WILL ALREADY BEAT ANY PONY OUT THERE ANYWAY LOL, but iv thought about LT's and while the stock manifolds are off do the opti and plugs and wires, or put new gears in the rear end....opinions?
Old 12-29-2008, 09:24 PM
Elliott's94Z's Avatar
All the above
LT's for sure, Opti is a good idea along with the plugs and wires. Chane the gears out when you get some more cash. You have a A4 or M6?
Old 12-29-2008, 09:26 PM
Black94Z28's Avatar
Nitrous!
Old 12-29-2008, 09:28 PM
Originally Posted by Black94Z28
Nitrous!
Yeah throw a 250 shot through the stock manifolds Joke!
Old 12-29-2008, 09:30 PM
EliteCamaro94's Avatar
yep longtubes and the opti and plugs, then like elliot said do gears afterward when u get more cash.
Old 12-29-2008, 10:03 PM
z28rob18's Avatar
change the coil wen u do those things itd be kinda stupid to do new plugs wires and opti and still have the 105k mile coil
Old 12-29-2008, 10:07 PM
cat or no cat? i know that if i do LTs i have to buy a Y pipe for my catback, a friend of mine said that heads would make a HUGE differernce but IMO that would be stupid to not just rebuild the whole motor if i do that..also does anyone know the stock gear ratio in my car?
Old 12-29-2008, 10:09 PM
Originally Posted by Elliott's94Z
All the above
I have an A4
Old 12-29-2008, 10:22 PM
Green3spd's Avatar
Well does your state require emmisons? If not, then NO CATS...
With you being an auto, you could have 2.73 OR 3.23.. you can look for the RPO code in your glove box.. 2.73 for GU2---3.23 for GU5..???? Maybe wrong on the codes..
Old 12-29-2008, 10:25 PM
proace4's Avatar
look in your glove compartment or on the drivers side door. look for a code that says either GU2 or GU5... GU2 is 2.73s and GU5 is 3.23s... at 70ish you'll run about 2250-2500 with 3.23s. its what i would bet you have but i dunno for sure.
I live in KY so no emission laws but like i said its a daily driver but i dont guess that makes a difference. i thought about 3.73 gears but that might destroy my gas mileage even worse
Old 12-29-2008, 10:26 PM
proace4's Avatar
sorry for the double post... haha my itouch takes forever to reply on...
Old 12-29-2008, 10:37 PM
proace4's Avatar
i'm debating on the same thing... i've been told that with 3.73s you will run about 2600-2900 at 70mph. while i dont know how tall a tire the guy was running. but he said he got 20mpg...
Old 12-29-2008, 10:43 PM
I have an A4
I would suggest a 3.73 gear ratio then..If you wanna do mainly drag then maybe look into 4.10 but the 3.73 are a good overall gear choice for the A4
Old 12-29-2008, 10:45 PM
and wont kill gas mileage? i know u lose top end speed but i dont go over 100 ne way
Old 12-29-2008, 10:53 PM
Maybe a loss of and mile or two off a full tank..really no difference. As far as top end goes...I've hit 130 and still had plenty more to go
Old 12-29-2008, 10:57 PM
sweet...i found a set of gears for $189...not a bad price
Old 12-29-2008, 11:07 PM
What brand? Remember to get a new seal kit as well.
Old 12-29-2008, 11:09 PM
http://www.futralmotorsports.com/fms...asp?pf=2&pg=16
Old 12-29-2008, 11:14 PM
Them will work. I put one of those rear end covers on too since it was coming off. Nice little piece..
Quick Reply: Money Decisions
