Track times! NEED Help!
The car runs fine I did a compression check and all cylinders are fine and i did a fuel pressure check and it was a good 50psi all through the power band No poping or backfireing, and doesnt seem slugish of the line either...... i dont get it......
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
1 Post
still short shifting he should be quicker
damn my 383 i was shiftin at maybe 5500 just to be easy on the motor and i still pulled a 13.1 and the motor can hold 6500-6800 no prob and still pull that high just that high on my track would spin even into fourth when i was pullin through the trap lol
Your leaving alot on the table shifting that low!
I ran an 8.3 in the 1/8th on motor with bolt ons and that cam. It ran a 12.40 in the 1/4 on motor and it ran 8.0 flat 1/8 th with a 80 shot and 12.00 flat in the 1/4. On the juice my stock clutch slips and that was shifting at 6,200. My sig shows 4.10s but it actually has 3.42s. So something is definately wrong. I am also using the stock lt1 knock sensor. But I have a trifecta tune. Definate problems there.
D
D
Like the others have said, shifting that low with that cam leaves alot on the table. However there is more problems than just that. I shift there with a stock motor and click off high 12's low 13's. Something else is wrong in the package. It SHOULD be quicker than the #'s you are producing even shifting that low.
