burned up front O2 sensor???
Old 12-30-2008, 02:00 PM
impaled's Avatar
Default burned up front O2 sensor???
i think i burned up my front drivers side O2 sensor. i was on a long drive and i had a plug wire pop off and couldnt stop until an exit which wasnt very close so it was running on 7 cylinders for a while MIL flashing at me.
after i got the wire back on and crimped it harder, i have gotten a fault code for the bank one sensor one (precat drivers side) and have since twice. i have a few questions.
are the front O2 sensors the same as the rear O2 sensors?
i looked on summit and they had different part numbers so i am thinking
no, but would like to save money (if possible) i have the rear O2's sitting
around from the LT ORY swap.
if i seafoamed the hell out of the car could it clean it?
or is there an electronic parts cleaner i could use?
i am sure with the fuel running through the cylinder and exhaust it got soaked but i ran it 4 hours back and the code is still on. i am going to run autotap here in a few minutes so i will get back on that.
Old 12-30-2008, 02:55 PM
IronOutlaw's Avatar
Is the car running right, if so just get the code cleared. Im not positive but i thought that a code wouldnt go off until you cleared it.
Old 12-30-2008, 05:10 PM
impaled's Avatar
its been cleared. and came on again.
does anybody know of a sensor/electronics safe cleaner i could use on it?
or would i be best with some seafoam?
Old 12-30-2008, 05:16 PM
IronOutlaw's Avatar
I doubt seafoam would clean it, but its worth a try.
Old 12-30-2008, 05:25 PM
impaled's Avatar
that is kind of what i was thinking, but it wouldnt hurt.
i now learned the difference between the precat and post cat 02's. the precat are heated, thus they are not interchangable.
so does anybody know of a cleaner?
or could it be a wire issue?
is there a way to test the 02?
Old 01-02-2009, 09:15 AM
impaled's Avatar
i seafoamed it and ran the deep creep seafoam and no more code! just that i would let you all know.
Old 01-02-2009, 03:16 PM
IronOutlaw's Avatar
Wow, im glad to know that. I didnt think it would work like that but hell, i may give it a try when my o2s give me trouble.
Old 01-02-2009, 03:27 PM
yardd0g24's Avatar
If you had an O2 burn up the car wouldn't run right at all I would think..... just get the code cleared
Old 01-02-2009, 05:56 PM
impaled's Avatar
it was a nice suprise. all is good now and she screams like a demon.
Quick Reply: burned up front O2 sensor???
