Aftermarket fan
Old 01-01-2009, 09:07 PM
mikes98z's Avatar
Default Aftermarket fan
ok, while I am at it and I can't find info in the search, have any of you guys switched out the massive dual fan setup for a more lightweight slimmer design? Maybe a larger single fan,etc?
Just curious if its a worthwhile mod on shedding a few pounds and obtaining a little more room. Its pretty roomy already after everything I have done..
I will get some pice soon of my progress.
Thanks again!
mike
Old 05-13-2009, 10:16 PM
ikaros23's Avatar
oooo I've been thinking about the same thing these days. does anybody know something?
I'm taking out a few pounds from my car. btw the stock dual fan setup weight around 15 pounds.
Old 05-13-2009, 10:25 PM
whytryz28's Avatar
You can mount pusher fans on the other side of the radiator if you dont a/c to save room.
Old 05-13-2009, 10:59 PM
ikaros23's Avatar
noob question. what would be the difference between a single and dual fan setup? will my car overheat with a single fan. I'm really into weight reduction and want to drop as much weight I can .
Old 05-13-2009, 11:19 PM
litch2004's Avatar
one single large fan will compensate for the two smaller fans. not sure but might be able to tie into the original wiring.
Old 05-14-2009, 12:21 AM
ikaros23's Avatar
thanks for your info. I've heard a lot of people going with a stock fan from a 96 ford taurus. I have one sitting in my garage it feels lighter than the factory f-body but it might not be big enough to provide good air flow. what do you think?
Old 05-14-2009, 12:22 AM
litch2004's Avatar
im not familiar with the ford taurus fan so i really cant give you any advice on that.
Old 05-17-2009, 08:12 PM
ikaros23's Avatar
anyone else knows something?
