crane Lifters
Old 01-02-2009, 03:39 PM
white95birdta's Avatar
Default crane Lifters
I was recently given a brand new box of crane 99377 lifters and was wondering if they would be of use on my LT1 build. if not if anyone knows what application they are for i would love to have the info on these things. thanks! kevin
Old 01-03-2009, 07:27 AM
gsdave's Avatar
According to Summit's website, they're hydraulic flat tappet lifters for a SBC. You could use them in your LT1, but it would be a serious downgrade from the stock hydraulic roller.
Old 01-03-2009, 08:55 AM
Michigan Skip's Avatar
So, you're saying he can use flat tappet lifters with a roller cam?
Old 01-03-2009, 09:14 AM
gsdave's Avatar
No, I don't believe I said that anywhere.
If he felt compelled to use the lifters (I'm not sure why anyone would), he could use a flat tappet hydraulic cam in his LT1. Of course, he'd probably want to go with a carb and regular distributor at that point because I'm not sure how he'd drive the optispark unless a drive pin was added.
Old 01-03-2009, 09:18 AM
RamAir95TA's Avatar
Definitely not a wise idea. Hydraulic roller cams have steeper ramp rates that keep the valve at max lift for longer (hence why hydraulic rollers provide more HP). Flat-tappet lifters cannot withstand the increased ramp rates and, consequently, it would be pretty easy to wipe a cam lobe.
Hydraulic roller and flat-tappet combined is a BIG no-no!
Old 01-03-2009, 03:20 PM
ok thanks guys. any advice on where to try and sell these things then?
Quick Reply: crane Lifters
