95 z28 turbo
Old 01-02-2009, 06:17 PM
bulletguy's Avatar
Default 95 z28 turbo
installing a turbo on my friends camaro, what would be a good spark plug to use...383 ci. 8 lbs of boost..thanks guys
Old 01-02-2009, 07:24 PM
detroit_903's Avatar
I set mine at 35 gap running 7psi on stock lt1 with full msd ignition set-up
Old 01-02-2009, 07:34 PM
koolaid_kid's Avatar
I use the NGK TR-6, gapped at 0.035. It is one range colder than stock, and is supposed to be good for FI engines.
Old 01-02-2009, 08:14 PM
bulletguy's Avatar
he has the TR6 in it now, naturally aspirated...we bolted the turbo on today,still got a few thing to tighten up on it, i think its a 60mm..about 4 years ago i had a 96 z28 with a D-1 procharger with 14 lbs of boost,355 ci
with a fast ecu, and i used a TR8 NGK. i cant seem to fing them anymore,i know alot has changed in the last few years with these cars, so i wanted to see what you guys were running ..so i take it the TR6 will work?
thanks for the replys fellas
Old 01-02-2009, 08:16 PM
bulletguy's Avatar
if you dont mind,what kind of power are you making?
Old 01-02-2009, 08:52 PM
Jose93z28's Avatar
Default plugs
Using tr6s @ 8psi gapped at .35
