What cam for me?
Old 01-03-2009, 01:25 AM
blake110106's Avatar
Default What cam for me?
So the trans decided to go today so ive decided to pull both engine and trans. I have to fix and oil leak anyways.
ok now for mods. I dont plan on doing anything drastic to the car. basically I want to have a full bolt on cam only car but also want to get the most usable power out of the stock heads and bottom end I can. Also need help with what rocker, springs, lifters, PR's and ect to run. Also I want to be able to jump in the car and drive it when I want however I do have another car I could drive if need be.
Im planning to run around a 3500 stall converter. all this will happen within the next few months. Thanks alot for the help guys!
Old 01-03-2009, 01:35 AM
porksoda's Avatar
https://ls1tech.com/forums/lt1-lt4-m...wap-guide.html
Old 01-03-2009, 04:08 AM
I've read that. I just dont want to jump into it and buy something that wont suit me.
Im thinking about the cc305 and cc503. just want opinions on what cam would be the best
Old 01-03-2009, 04:41 AM
Counted Out's Avatar
And +2 on the CC503 too.
Old 01-03-2009, 09:30 AM
RamAir95TA's Avatar
CC503 is considered one of the best cams for stock headed cars.
Old 01-03-2009, 01:47 PM
robsquikz28's Avatar
503 baby
Old 01-03-2009, 01:54 PM
SS MPSTR's Avatar
another vote for the 503, but don't rule out the 305 or hotcam either.
Old 01-03-2009, 02:04 PM
SoxXpupPeT's Avatar
depends onw hat you want. if you want a high revving cam thent he 503 is good. i have a 154k mile short block and stock heads. ill be going with an LE cam
224/230 .560/.565 112 LSA. - 1700-6100 RPM
to be more specific. i just dont want to put to much on my bottom end or rear
Old 01-03-2009, 02:24 PM
my engine has 128K on it. I dont want to rev to high. maybe 6200
I think the cam will be the last thing I buy for the cam swap.
Anyone have suggestions on timing chain, rocker, lifters, valve springs, ect? Ive looked at the comp cam behive spring kit for 254 on ebay. Anyone know about what length PR's i would need. 7.2's?
also on the rockers there are some 1.6 RR's 3/8 stud self aligning mad by proform. Anyone run these?
Old 01-03-2009, 02:29 PM
SoxXpupPeT's Avatar
yeah mine too. i just picked up a stock timing chain and cam sprocket from gmpartsdirect. that and LS7 lifters. i already have comp cams 918 beehives and comp cams 1.6 roller tip rickers. i also used 7.2" trickflow hardened pushrods and guideplates. so far im very happy
Old 01-03-2009, 04:17 PM
You can get the Crane Spring kit that will come with locks and retainers for about $180 on Summit. As far as the Proforms, I've heard alot of bad things - I even remember one person saying he wouldn't put them in his lawnmower.
Your pushrod length is going to vary depending on your lifters and a few other things. I suggest buying those last, and buying a pushrod length checker to be sure you get the right ones.
Old 01-03-2009, 05:06 PM
ok so Im going to count the proforms out haha
ive been reading more and more on here. I think Im going to get some LS7 lifters. Im not sure on NSA or SA rockers. What one clear stock valve cover and which dont? anyone have any input on this. I hate going through 100 threads and find just one that has any good info.
Old 01-03-2009, 05:14 PM
tspence45's Avatar
I'd recommend these for the springs. https://www.patriot-performance.com/...&cat=52&page=2. A little bit more pricey than the Cranes. But, last time I checked, the Cranes are on backorder everywhere and are nearly impossible to get. Plus, the Patriot's can handle more lift, and come with titanium retainers, instead of steel, and valve stem seals.
SA will clear the stock valve covers most of the time - but even if you have to modify them, it seems pretty easy.
When I was looking for good, but cheap rockers, alot of people pointed me in the direction of Scorpion Roller Rockers. I was able to get a set, brand new, for around $200 and they look VERY nice.
There is some guy on Ebay that sells them at the best price I could find online.
Old 01-03-2009, 05:27 PM
ABA383's Avatar
Check out Lingenfelter too...I still think the LPE 211/219 .533/.560" is a great choice...They also have the dual springs/retainers on sale...These are the same springs and titanium retainers I've been running for 13plus years! Its definitely worth a phone call to them...260-724-2552...
--Alan
Old 01-03-2009, 05:31 PM
Those are nice and right at the price of the Beehive springs. Thanks for the link
I seen the scorpion's on ebay. The cheapest I could find for the LT1 and such is 279.99 shipped. the $200 ones I seen was for 55-85 v8's
Just messaged a guy about some summit rockers he has. they are 1.6. I believe its these http://store.summitracing.com/partde...&view=1&N=700+ he wants 165 shipped
Old 01-03-2009, 05:40 PM
Elliott's94Z's Avatar
Have Lloyd grind you up his version of the 503! It will be a strong runner for sure!
Old 01-03-2009, 05:59 PM
They guy I messaged has the NSA summit rockers and not the SA.
whats his website? Ive read lots of good things about him.
EDIT: found his site
Old 01-03-2009, 06:04 PM
http://www.elliottsportworks.com/lt1.html
Rather then just buying the CC503 I would just have Lloyd grind you one up. You should see better gains with his as well. Keep in mind some of the specs on here are old and have been re-worked. Call him up and he will help you figure out a good way to go.
Old 01-05-2009, 05:36 PM
ok so I have comp magnum 1.6 SA roller tip rockers and LS7 lifters on the way.
for spring Im going with the patriots. Looking at lloyd elliott 228/235 cam. I dont have emissions here and it says its the non emissions cam of the 224/230. Would I be ok running the 228/235 cam with the 1.6's? it will put the lift close to 600 and with the duration im a lil iffy.
also how will i check what length i will need with the pushrod checker?
Quick Reply: What cam for me?
