poly mount opinions please
I'v got the motor and tranny out of my 1993 TA right now. I'm doing a bunch of stuff to it and was wondering what you guys think od polythane mounts. Do they make much of a difference? I can get all the mounts in a polythane kit from summit for 100 but just dont know if its worth it. Any info is appreciated. thanks!
I know they are a lot stiffer than rubber but not as stiff as solid mounts ...I just installed mine on my k-member but haven't put the car back together yet so I can't really give you any feedback but I can tell you that the same kit is 75 bucks at byunspeed
the stock rubber mounts have a lot of give and they rot the fastest. but they probably woundn't rot before the end of the lifetime of the car. polys are stronger and last longer, less give. you've heard of poly bushings for your swaybars right? they are much better than the stock rubber ones or whatever they come with. in general poly is better than the stock mounts.
I don't feel any more vibrations then i did when they were stock. I have poly engine and trans mounts. Car has 155,000 on it so i know the stock ones weren't in the best shape either.
well the only thing I notice is when I rev the engine the whole car shakes buts that normal. Any vibrations are most noticeable during the first couple hundred miles after that it should be smooth...Imo.
Did you konw solid mounting can kill main and rod bearings? I did it to my 1994 gmc jimmy and you wouldent believe the vibrations you get lol. I have seen a drop in oil pressure since I did it too . Probubly should switch them out but it's a PITA and its getting a v8 out of one of my old 1991 rs camaro
In Camaros there's a bit of a problem with (at least Energy Suspension's) the trans mount, that it needs a spacer or some such. They've since corrected it (as of about late summer of 08). I ran a Energy poly trans mount in my 91 Formula and it was nice. Apparently the LS ones are the same internal design as Energy's with the locking metal plates that only allow flex so far, but the price of the Poly vs LS is so minimal. I know TPiS sells Energy stuff for dirt cheap. They're a sponsor too.
i have the motor mounts i got them for x-mas so there not on the car yet but i have had the trans mount on the car for a year, with the trans mount you can feel a lot more vibration with it
BTW here's TPiS' price, and while I haven't shopped around, I know it to be pretty darn good heh
800-074 Bushings, Tranny Mount 85-98........$25.00
I think it has something to do with having stock motor and poly trans mount. The engine moves alot more than it would with poly mounts and transfers all vibrations through the trans.
Or it's exactly what I said about the Camaro's problem You need to shim them to fix the vibration problem. And why it's Camaro and not Firebird, I don't really recall, but it's a 4th Gen Camaro specific issue.
The original threads with all the information were deleted since Energy isn't a sponsor, but here's the only bit of info I can provide (which can actually aid this thread now that I re-read it!)
Hey Clint,
I guess the forum wants me to be a paying sponsor in order to get information. I was just trying to get info for the mount but at the same time give away some cool product. Oh well, they spoiled it for everyone.
Well I got in an automatic 01 camaro ss and it didn't like us and ran poorly. We traded that for an 02 WS6 6 speed and got a lot of the critical information.
My boss is pulling the plug on this project because we found out that our mount is a little taller than a factory brand new mount. We may be changing our mount but as politics work, it is out of my hands now.
I did find out that a lot of the vibration goes away when a poly torque arm mount is used along with the trans mount.
As for the arguments of drive line and changes, factory was set at .4 degrees and our mount brings it to .8 degrees. you have 3 degrees to play with so driveline vibration through angle change is non existent.
EDIT: Actually now that I think about it, maybe it was REMOVING the shim that fixed the problem... "NOTE: WHEN INSTALLING- YOU MUST USE SUPPLIED BASEPLATE." and by Shim, I mean Baseplate.
