new bottom end
Old 01-06-2009, 04:33 PM
97lt1z28's Avatar
Default new bottom end
I am rebuilding my bottom end and was wondering what kind of bearings you guys have used for your rods and mains (with part number if you can). I was also wondering about rings. Also, when i was ermoving my old motor i broke the sensor going into my oil pan, does anyone know where i could buy another one of these?
Old 01-06-2009, 07:43 PM
97lt1z28's Avatar
i am also looking for a new high volume oil pump..any suggestions?
Old 01-07-2009, 05:06 AM
slagger's Avatar
i'm using clevitte 77 rod bearing were almost $8.00 each plus clevitte 77 main bearings something like $80.00
I would defintly recomend the Melling Select 10552 oil pump
i'm runing the 10555 its 25% more volume but the 10552 is 10% more volum should be great. they are around $70.00
Old 01-07-2009, 09:25 AM
dafhturbo's Avatar
I just finished my short block using clevitte 77 main and rod bearings. I also broke the oil level sensor. Advance Auto sells them.
Old 01-07-2009, 05:49 PM
97lt1z28's Avatar
those are just standard bearing for a chevy small block right
Old 01-07-2009, 06:04 PM
fergymoto's Avatar
Clevite makes several different types of bearings such as the A series, P series, H series, and coated H series bearings. Aluminum is stock replacement, P is slightly better and H is more high performance stuff. Clevite 77 is just the name brand.
Quick Reply: new bottom end
