what should my car run?
It has a TNT nitrous kit 150 shot,it has some suspension work,12 bolt rear end with 4:10 gears CNC LT4 ported and polished cylinder heads,CNC LT4 ported and matched intake,crane 222/230 cam,comp cam 1.6 roller rockers,holly 58mm throttle body,3"Quick time electric cutout,Fuel pump hot wire, 255 lph Granatelli motor sports F-body in-tankfuel pump,Y-pipe, valve covers,GM performance LT4 extreme duty timing chain,SLP stainless headers,SLP air induction w/k&n filters,accel 300+ ignition.Pro 5 shifter, The car is lowered 11/2 inchs, it has subframe connectors,rear control arms ,There is a roll cage in the car, The car was dyno tuned by thunder racing. Its a 6 speed
Moderator
I agree with Travis. What tire is it on? If it hooks on dope I bet that bitch will rip, your main problem is going to be hooking it out the hole. But he has a good rear under it, just make sure he got a tire on it. Dyno numbers dont really mean much, power is only a 1/3 of the combination. It's easy to make power with a LT1 with the right set up, when using a power adder like nitrous, it becomes really easy. But the other 2/3 comes from suspension, gear, tire height, weight and driver.
This is odd. Im in noway trying to be argumentitive,but multiple people on this site will vouch,we have a 96z with a muffler,a 26x10.5 slick and a cai,with a 125hp shot go 11.81@114 with a 1.68 60ft. How is his car only gonna go mid to low 11s? We went 11.39@117 with a better(more efficient)kit,stall,and a hypertech programmer. The car is 100% full wieght aswell. Motor still remains bone stock!
Moderator
so, what gives?
i do have something wrong thats why i asked what i SHOULD run because it ran a **** time. it has a p0122 code so i replaced the TPS but it still has the same problem. i was told it may be the knock sensor. if its that it can back the timing way off and that would explane the lack of power but im not shure what it is for shure.
if it was dyno tuned i would imagine that the km was de-sensitized. i would think you should be real low 12s to high elevens on motor. there are a few of us bolt-on only cars running mid twelves.
